66 400 E block B heads in 67 442,, 68 455 F block C heads N crank
Old February 15th, 2012, 09:07 PM
ut442's Avatar
So I would like some input on engine build combo options. Should I simple rebuild the 455 with its cast N (nodular) crank and that is the best engine. I am guessing most ponys anyway. Or should I take the 66 forged crank and connecting rod and make a 427 engine from the 455. I really would like to hear what the you would do?
ut442 is offline
Old February 16th, 2012, 04:44 AM
cutlassefi's Avatar
Go with the larger bore of the 455, it'll breath better, not to mantion the added bonus of the extra cubic inches.
Jmo.
cutlassefi is offline
Old February 16th, 2012, 09:12 AM
Run to Rund's Avatar
The second option you describe is a 425. You will get mixed reviews on 425 vs. 455. The 400 block with its smaller 4" bore is better for restorations than max power, as stated above.
Run to Rund is offline
Old February 16th, 2012, 09:13 AM
BTW, it is easier to find good (aftermarket) rods for the 455 at low cost, although rocket Racing does offer 425 rods made by Scat. There will be a better selection of 455 pistons also.
Old March 9th, 2012, 09:58 AM
Menatour's Avatar
I have the 455 w/C heads. Absolutely no complaints.
Menatour is offline
Old March 9th, 2012, 11:57 AM
Vega's Avatar
Have you seen the crank from the 68' and are sure it is an N crank? i only ask because some 68's got rare forged steel cranks (in the process of disassembling one now)
Vega is offline
Bernhard
November 24th, 2022 09:12 AM
Oldsmaniac
June 1st, 2012 01:20 PM
Oldsmaniac
April 25th, 2012 06:55 PM
sx455raidercelticfan
November 23rd, 2010 05:45 AM
jman07
March 7th, 2008 08:42 PM
Quick Reply: 66 400 E block B heads in 67 442,, 68 455 F block C heads N crank
