Pics of motor mounts and frame mounts?
Old March 6th, 2012, 07:10 PM
XCELERATIONRULES!
Nasty455's Avatar
I would appreciate any restoration photos showing where your frame mounts are located.
Part numbers would be great.
I notice there are 2 location on the engine where the engine mounts can go.
I'm wondering by moving the engine forward,If I could use a long tail transmission.
If the motor is too far forward,I could go with electric fans.
Both A body and B body pics appreciated.
Thanks.
Nasty455 is offline
Old March 6th, 2012, 08:06 PM
2blu442's Avatar
What year/model of car are you working on? My experience has been the 1964-72 A-bodies all used the two bolt holes closest to the rear of the block. I know I've had some 1967-68 full sized with big blocks that used the two forward most bolt holes in the block. Check out the following thread for information on part numbers. Let us know if you have any questions or if this isn't what your looking for. John
https://classicoldsmobile.com/forums...tion-list.html
2blu442 is offline
Old March 7th, 2012, 04:22 PM
XCELERATIONRULES!
Nasty455's Avatar
72 A Body.
I have an olds,Pontiac,and Chevy 350 available.
The cutlass motor is in the best condition.
I have a turbo 350 short tail and a turbo 400 long tail available.
I prefer the heavier duty unit..but don't want the added expense of shortening or buying a new drive shaft if I can help it.
The Pontiac and Chevy motors originally used the rubber mounts on the frame,with steel brackets on the engine.
They came off an F body.
The A body chassis has the rubber mounts on the engine,and metal frame mounts on the frame.
I would just like detailed photos of where the engine mounts and which holes are used for the mounts.
All A bodies use the same frame as long as the wheelbase is the same.
I understand the convertible frame is heavy duty.
Nasty455 is offline
Old March 8th, 2012, 09:55 AM
Thanks.
You can't move the engine forward - the oil pan sump will hit the steering linkage. There are three motor mount holes on each side of the block. The front two are used for the 1964-70 full size cars and the 1973-74 Omegas. All the rest use the rear two holes.
joe_padavano is online now
Old March 8th, 2012, 10:18 AM
oldzy's Avatar
350
oldzy is offline
Old March 8th, 2012, 07:12 PM
XCELERATIONRULES!
Nasty455's Avatar
Thank you.
Much appreciated.
Nasty455 is offline
Old March 20th, 2012, 11:24 AM
XCELERATIONRULES!
Nasty455's Avatar
Looks like you used standard grade 5 hardware?
Do the nuts go topside like your photo?
The goofball previousChevy Owner...liked to weld.
He welded mounts in ,rather than buy the correct mounts...I have no hardware.
Thanks.
Nasty455 is offline
Old March 20th, 2012, 12:30 PM
oldzy's Avatar
Mine? If so, they are Grade 5 IIRC. The nuts go topside just like originally. Basic type nut with a lock washer in between (tricky to get a socket/wrench on a few bolt heads though). I got them from inlinetube (as well as the two long pointy motor mount bolts).
pg58 of http://inlinetube.com/PDF%20catalogs...dsmobile04.pdf
oldzy is offline
Old March 20th, 2012, 04:57 PM
XCELERATIONRULES!
Nasty455's Avatar
Thank you.
I'm thinking I can get grade 8 bolts locally cheaper.
Nasty455 is offline
joesw31
May 31st, 2015 04:17 PM
78 omega 468
November 19th, 2011 10:03 PM
TripDeuces
June 10th, 2010 08:49 AM
flatoz
March 15th, 2009 02:03 PM
gthmcty1
February 26th, 2009 06:21 PM
Quick Reply: Pics of motor mounts and frame mounts?
