Help with the dreaded 2.56 ratio differential
Old November 7th, 2009, 02:53 PM
'71 Convertible
LIMEGREEN71's Avatar
I'm about to go through the differential out of my '71 Supreme Convertible. As expected, it's the dreaded 2.56 ratio. It is my understanding that the carrier won't accept a gear swap without a spacer and longer bolts. I really want to put a limited slip unit in anyway, so I'm I correct that the housing (stamped R6 if I remember correctly) will be fine and if I'm going to change carriers then the whole 2.56 stock carrier problem doesn't matter? What I'm hoping is that my housing will work fine with a limited slip (Eaton or other) and 3.42 gears. Thanks for any advice!
LIMEGREEN71 is offline
Old November 7th, 2009, 05:10 PM
BobsW32
Bobsw32's Avatar
Yes you will need a new carrier and obviously the gears...
What are you going to do with the 2.56.....I may be interested
Bobsw32 is offline
Old November 7th, 2009, 06:23 PM
'71 Convertible
I won't have any use for the gears or the carrier. It would make someone a very servicable replacement as my car has only 57K miles and ran beautifully prior to disassembly.
Old November 8th, 2009, 12:38 PM
monzaz's Avatar
10 bolt 8.5
You are lucky to have the 10 bolt 8.5 as the parts are pretty readily available.
eaton
dura grip eaton
true trac
auburn
factory reconditioned units are all available
3.08 3.23 3.42 3.73 3.90 4.10 4.56 4.88 and on are gears out there new and used.
If you need a quote on parts PM and will give you something to start with your search. Jim
monzaz is offline
Old November 8th, 2009, 01:25 PM
MacGuyver's Avatar
People really want those 2.56's? I've been sitting on a set for a bunch of years now. I figured that it'd be fun to swap out the 5.00's in my W-31 and see what she'd do for top end. The 5.00's only let her get up to 105. I don't know if I'd want to be putting all the extra strain on that aluminum carrier though. : )
MacGuyver is offline
Old November 8th, 2009, 05:19 PM
71 cutlass convertible
lshlsh2's Avatar
I have a 2.56 in my conv. It is going to stay. I want a nice cruiser. Right now she purrs down the road 60 to 70 no problems.
Larry
lshlsh2 is offline
Old November 8th, 2009, 06:30 PM
'71 Convertible
Oh, I understand Larry! I actually bought my car in Tampa and drove it home to north of Birmingham, AL ... over 700 miles. Not only did it drive beautifully on the Interstate, but it got fantastic economy as well. That said, it's undergoing a body-off restoration and the days of roadtrips are over. A little around town and that'll be about it. I've done an extensive rebuild of the 350, which appears stock other than the intake, but it isn't stock . That, mixed with the 3.42 gear should wake it up a little!
Old November 8th, 2009, 07:30 PM
stlbluesbrother's Avatar
Wink
The 2.56 ratio may not impress your buddies, but chicks don't seem to mind the one in my Olds
... just teasing
stlbluesbrother is offline
Old November 16th, 2009, 07:12 PM
Hydro462's Avatar
The 2.56 works great with a TH-400 with a 2.75 low gear set...I wouldn't trade my 2.56 for anything....
Hydro462 is offline
Old November 17th, 2009, 05:57 PM
monzaz's Avatar
gears
The freeway gears do better smoking on the burnouts because the tires are actually spinning at a higher rate of speed. NOT rpm SPEED. Look at your speedo and you will see what I mean. lol. The motor will not even be working up a sweat and the tires will be smoking like crazy... Jim
monzaz is offline
Old November 17th, 2009, 08:36 PM
70 cutlass s's Avatar
You go from 2.56 to 3.42 you won't be waking it up a little. It will be like hitting Big Foot with a stick when he's a sleep. You better run.
70 cutlass s is offline
Old November 17th, 2009, 11:58 PM
svnt442's Avatar
Hey I ran a 13.89 @ 97 MPH with 2.56 gears (at the top of second gear). I just shifted into 3rd when I went through the traps. Don't knock em too hard. And that was with a J headed 455.
svnt442 is offline
Old November 18th, 2009, 05:16 PM
Lady72nRob71's Avatar
Just obtain another diff assembly and upgrade that to the ratio of choice.
Then put the 2.56 one back in the closet in case you ever want to continue your road trips!
However, posi is almost a must with these cars, even with the 350s.
Don't some of the stock GM truck gears / carriers fit into these units?? I heard rumors...
Lady72nRob71 is offline
Old November 25th, 2009, 09:43 AM
507OLDS's Avatar
Most of the trucks with 8.5's have the gov-lock posi unit,which is equivalent to a grenade with a loose pin.
You will be very happy with a 3:42 in your car.You might even get better mileage than you do now.Your gear is a torque multilier.Having a 2:56 is like having it chained to a brick wall.Not as easy to get going,but runs at a lower rpm when cruising.It just takes a little more squirt to get it moving.The 3:42 will be better all around.
If you need help finding parts,I have plenty,new & used/rebuilt.
507OLDS is offline
Old February 22nd, 2010, 03:45 AM
car nut farmer
71rocket's Avatar
Interesting topic. I've been wanting to pep up my Cutlass, guess I better see what's in it now.
71rocket is offline
White_Knuckles
March 23rd, 2014 10:38 AM
DLaz70OLDS98
Drivetrain/Differentials
January 22nd, 2014 09:55 AM
Creativeindy
April 26th, 2013 06:13 PM
J-(Chicago)
February 13th, 2012 05:49 PM
74 Omega
April 3rd, 2008 03:00 PM
Quick Reply: Help with the dreaded 2.56 ratio differential
