Will a 73-77 Cutlass rear end bolt into a 65 Cutlass
Old November 24th, 2014, 09:55 PM
rcdynamic88's Avatar
I've seen several posts about how a 64-67 A body rear end will bolt into a 68-72 A body and vice versa. With the main difference being the 68-72 rear end is 1" wider per side. Any chance the 73-77 Cutlass A body rear end will bolt in to a 65 Cutlass? Are the control arm mounts in a different location? Is that rear end even wider? Just wondering because I might have a line on an aftermarket Ford 9" rear end, but it is set up for a 73-77 A body.
rcdynamic88 is offline
Old November 24th, 2014, 10:44 PM
oldsmobiledave's Avatar
Fyi
wont fit & shocks mount on wrong side of axle.
oldsmobiledave is offline
Old November 25th, 2014, 12:14 AM
Thanks Dave. Heck, I even had a 1973 Olds 442 (back in 1973!), but I didn't remember the shocks being mounted in a different location.
Old November 25th, 2014, 08:35 PM
monzaz's Avatar
Different
Even more than that is different
Drive shaft will need a cutting
Upper control ARM bushing mounts are in a totally different cast location
Spring perches are in a different location
whole rear is way wider...
Shall we keep going.
Sorry there are better options than this one out there.
Good luck on the hunt.
Jim
monzaz is offline
Old April 7th, 2015, 07:04 AM
Welcome. I moved your post to it's own thread, as the original thread you responded to was about axles to fit a 65. You'll get better response with your own thread (though since Jim has already answered, that's about the best you'll get). Good luck and post some photos of your car as an intro.
joe_padavano is offline
Old April 7th, 2015, 11:21 AM
I combined your 2 threads into 1. Good luck
oldcutlass is offline
ryneves
April 26th, 2015 06:19 PM
350TurBRO
September 12th, 2014 11:52 AM
Mikes442
Drivetrain/Differentials
January 31st, 2014 03:57 AM
squirell
June 25th, 2013 12:00 PM
costpenn
September 16th, 2011 11:08 AM
Quick Reply: Will a 73-77 Cutlass rear end bolt into a 65 Cutlass
