Decoding Vin #s
Old July 21st, 2010, 07:12 PM
Wyze's Avatar
Decoding Vin #s
Everytime I try running my vin # I'm told it has to be 17 characters!!!!
I don't have but 13 on my 68!!!
Can someone please help????
Thanks in advance!!!!!!
Wyze is offline
Old July 21st, 2010, 07:33 PM
stevengerard's Avatar
where are you running it and what are you trying to find out, there isn't much to a 68 VIN except the model, body style, year made plant it was made at and its sequence number.
344678M123456
3 olds
44 - 442
67 - convertible
8 - 1968
M Lansing
123456 = 23,456 car on the assmebly line (number started at 100,000
stevengerard is offline
Old July 21st, 2010, 07:50 PM
If you post your VIN, one of us can give you the info you want. Maybe also get the cowl tag info, that's also fairly easy to get info off of.
Allan R is offline
Old July 21st, 2010, 09:22 PM
That's because the on-line VIN services are only designed to handle 17 character VINs, which started in the 1981 model year. In many cases, records for the older cars don't exist electronically.
joe_padavano is offline
Old July 22nd, 2010, 06:00 AM
Wyze's Avatar
342878M137366
This is my vin!!! Thanks!!!
Wyze is offline
Old July 22nd, 2010, 06:14 AM
mmurphy77's Avatar
17-digit vins did not become mandatory until 1981. GM vins were 13-digits through the '60s and 70s. Carfax and other vin seach databases will only work on '81 and up vehicles.
mmurphy77 is offline
Old July 22nd, 2010, 07:26 AM
STOP call'n it a Chevelle
arodenhiser's Avatar
Check this site out.
http://www.v8cars.hu/oldsvin/decode.php
throw your VIN in and it will tell you...
342878M137366
Year:1968
Division:Oldsmobile
Series:Cutlass Supreme
Body:2dr Coupe
Plant:Lansing, Michigan
Serial #:137366
I do not think your VIN can tell you anything else.
Adam
arodenhiser is offline
Old July 22nd, 2010, 12:43 PM
Wyze's Avatar
You the man!!!!!!
Now I've gotta decode the cowl tag!!!!
I think that the info I was really looking for!!!!!!
Wyze is offline
Old July 22nd, 2010, 01:15 PM
Lady72nRob71's Avatar
I was trying to get an insur. quote last year and they told me their system would not accept my 78 Pinto's vin cause it was too short.
I told them thats all there is - toss in some 0's in front if you want. They ended up quoting me for an 81 escort! Stupid dumb computer systems...
Lady72nRob71 is offline
Old July 22nd, 2010, 01:27 PM
You the man!!!!!!
Post a picture of it or type every character and someone here can/will figure what everything is.
If you have the original engine, the number stamped on it or the oil fill tube may hold some more info.
Adam
Old July 22nd, 2010, 02:53 PM
Wyze's Avatar
The motor didn't come in my car, I pulled it out a 69 Cutlass!!!
I'm just trying to get as much info on my car as I can!!!!
To bad I wasn't lucky enough to find the build sheet hidden in it somewhere!!!!
Wyze is offline
Old July 22nd, 2010, 05:09 PM
I hope Joe or some other guru can verify/correct this. I looked through my '68 service manual and this is what I read.
ST - 68-34287 - 1968 Cutlass Supreme Holiday Coupe (2 door no posts)
BODY - LAN 136500 - Lansing Assembly Plant, 136500 is the Fisher Unit Number (no information can be found in this)
Paint - C-F - C is code for Provincial White (maybe white vinyl top) F is for Teal Frost (Body Color ?)
TR 989 - Sienna (Reddish Brown) interior with Vinyl Bench
10A - Not sure, Might be accent stripe (#10?) in black, A is the code for balck stripe.
This sounds like a oddish color scheme, but it was 1968. A light blue bodied car with white vinyl top and black stripes, with a reddish brown interior.
I hope some one else chimes in an confirms or denies this.
Adam
Old July 22nd, 2010, 05:38 PM
Wyze's Avatar
Man that would have been 1 ugly combo!!! Lol
Thanks,
I believe the body came white with frost blue interior, it had a vinyl top but it was long gone when I got the car!!!
10A is weird because I saw no sign of a stripe!!!!
Hopefully someone else will take a crack at it!!!!
Wyze is offline
Old July 22nd, 2010, 05:47 PM
svnt442's Avatar
10A is the build month and week. 1st week of Oct.
svnt442 is offline
Old July 22nd, 2010, 05:52 PM
Wyze's Avatar
What about TR989??
Wyze is offline
Old July 22nd, 2010, 07:11 PM
svnt442's Avatar
svnt442 is offline
Old July 22nd, 2010, 07:32 PM
Wyze's Avatar
I don't think that's correct!!!
My dash & the couple pieces that where in the car are frost teal!!!!
I know the bench seat is what came in it due to the column shifter!!!!
Was it normal to have different color seat and panel pieces????
Wyze is offline
Old July 22nd, 2010, 07:44 PM
svnt442's Avatar
Just because it came with a column shifter doesn't mean it didn't come with buckets.
svnt442 is offline
Old July 22nd, 2010, 09:04 PM
Wyze's Avatar
Wink
You're right about that!!!!!
Smh at the thought of some 442s coming with a front bench seat!!!!
Wyze is offline
Old July 22nd, 2010, 09:18 PM
Wyze's Avatar
Here my baby when I first saw her!!!
Wyze is offline
Old July 22nd, 2010, 09:19 PM
Provincial White with a Teal Frost painted roof and a Teal interior. A painted top will have the same stainless trim as a vinyl top equipped car where the two colors meet.
1969w3155 is online now
Old July 22nd, 2010, 09:31 PM
Wyze's Avatar
Well thank you!!!!
I believe you've solved the mystery!!!!!
Wyze is offline
Old July 23rd, 2010, 05:08 AM
German442's Avatar
....Which really means the stupid, dumb person who wrote the software!!!
Ralph
German442 is offline
Old January 6th, 2017, 02:06 PM
1968oldscutlas's Avatar
Smile 1968 cutlass vin decode
can you do my 1968 cutlass? 3428781111584
1968oldscutlas is offline
Old January 6th, 2017, 02:08 PM
342878M137366
Year:1968
Division:Oldsmobile
Body:2dr Coupe
Serial #:137366
Adam
Old January 6th, 2017, 02:14 PM
You know we heard you the FIRST time, right?
3428781111584
3 = Oldsmobile Division
42 = Cutlass Supreme
87 = Holiday Coupe (2dr HT)
8 = 1968 model year
1 = Oshawa, Canada assembly plant
111584 = sequential build number
Old January 10th, 2022, 03:19 PM
brotzeit's Avatar
Mine is
336879M162651
How is this decoded?
brotzeit is offline
Old January 10th, 2022, 03:28 PM
Oldsdruid
rocketraider's Avatar
Originally Posted by brotzeit
Mine is
336879M162651
Same as above except 36= Cutlass with V8 engine, 9= 1969 model year, M= Lansing MI assembly plant.
rocketraider is offline
Old January 10th, 2022, 03:49 PM
Mine is
336879M162651
VIN Magic or look in your CSM
http://vinmagic.com/
Vintage Chief is online now
Supreme68
March 22nd, 2010 06:54 AM
rallygreen
September 15th, 2009 04:02 PM
jrblanke
December 25th, 2007 01:49 PM
coldone1
March 20th, 2007 09:38 PM
DesertToro
January 16th, 2007 07:10 PM
Quick Reply: Decoding Vin #s
