Headers Recommendation please
Old April 1st, 2024, 02:50 PM
davidtuf's Avatar
Hi, I have a 68 442 with a 455 in it can someone please recommend some headers that will work without scraping?
Thanks,
Dave
davidtuf is offline
Old April 1st, 2024, 03:15 PM
70W-32's Avatar
Thornton Shorties
70W-32 is online now
Old April 1st, 2024, 04:24 PM
Shortie headers provide all of the expense and leaking gaskets of real headers without the pesky extra horsepower. If you want to be a poser, get shortie headers. If you want an actual power increase for your money and effort, get real full-length tuned headers. ARH are the best and priced accordingly.
joe_padavano is offline
Old April 1st, 2024, 06:52 PM
Full-time Taxpayer
Qwik71442's Avatar
Thanks,
Dave
American Racing Headers tuck up as tight as I’ve seen. Have installed half a dozen sets or so. Best fitment by far.
Qwik71442 is offline
Old April 1st, 2024, 07:51 PM
without scraping?
That might depend upon your vehicle’s ride height. I’ve seen some cars with the 4 wheel drive look and others that are dropped significantly.
Fun71 is online now
Old April 1st, 2024, 08:26 PM
BackInTheGame's Avatar
I've got Hooker 3902s on my '68 4-4-2, 400CID, 4spd. They do not scrape the ground and only had minimal interference on the bell crank.
BackInTheGame is offline
Old April 1st, 2024, 09:00 PM
66SportCoupe's Avatar
Chinese 250 dollar stainless works for cheap.
66SportCoupe is online now
Old April 2nd, 2024, 05:48 AM
ajr2820's Avatar
I have the Doug's headers on my 72 Supreme. Fit perfectly.
ajr2820 is online now
Old April 2nd, 2024, 05:04 PM
herkguy's Avatar
Originally Posted by 70W-32
Thornton Shorties
I use these also, drops some weight, are very well built and clean up the bay nicely.
never had a leak yet and have certainly not ground them off on the road..hehe
Is this for street or strip, if strip then you should read the performance section of this site.
What have you done to the motor.
1.Bore/ Stroke or stock
2 upgraded cam or race cam or roller cam. (Where is its power band)
3 roller rockers
4 intake/ carb upgrade
5 ported heads
it all plays into any results from the headers
Dont forget, a lot of people online will post up a dyno comparison chart from full length to stock or shorties, but almost all of them are tested with open exhaust. You might see a nice 7-10 hp gain over shorties or 15 hp gain over stock, but if you put on a corker exhaust, you just wasted your time and money. A lot of the basic super turbos to keep the noise down don’t flow enough to see the full gains so you will need something a little louder.
you will need open, cut outs or a really free flowing muffler to get all the benefits.
I used the Dynomax ultra flo which are straight through with no restrictions, sound great but will drone…ugh
i now use the Dynomax 17792 turbos to try and not restrict flow. They are 3” full internal with directors. I had to weld on 2 1/2”reducers to attach to my system.
I made a cruiser though, a 30 over 455, mild cam, roller rockers and ported heads.
honestly I think I get more out of the heads than any header would net me.
Mine now runs way better than my 69 HO with D heads unported and same power train/ gears and weight.
make sure to get some performance baselines of your car before the changes and then go check again after the headers. Chassis dyno, Track it, Gtech, or Draggy if you have a safe place to practice.
They will make numbers on a dyno, you need the whole package to make big gains on the street though, oh and they sound great….just some thoughts.
66 sport coupe races his car with the Chinese headers still and it moves quite well!,
herkguy is offline
Alaska442
November 1st, 2023 05:01 PM
bronze66f85
August 21st, 2023 06:15 PM
montvaleplace
March 24th, 2019 05:29 PM
Oldracerjones
December 3rd, 2015 08:27 AM
gbodyfan
June 13th, 2010 07:54 PM
Quick Reply: Headers Recommendation please
