How can I find vehicle description via VIN# ?
Old April 17th, 2024, 09:06 AM
reginaldw553's Avatar
I just bought a 1964 Oldsmobile 98 with VIN # 884M043673 on the Title paperwork but the VIN # tag is not attached to the inside of the driver's door. Is it possible for me to decode the VIN above and determine the body type and the color of the car?
reginaldw553 is offline
Old April 17th, 2024, 09:26 AM
Old April 17th, 2024, 09:31 AM
jaunty75's Avatar
No. GM VINs for 1964 didn't tell you much more than you could glean by just looking at the car.
884M043673
8 = 8-cylinder engine
8 = 98 series
4 = model year 1964
M = Lansing assembly plant
043673 = serial/production/sequence number at the Lansing plant.
You can get some of the information you're looking for on the body cowl tag, which should be mounted on the firewall under the hood, either on the driver's or passenger side. If you can find it, take a clear photo of it and post it here. If you post photos of the car itself, we can tell you the body style immediately.
jaunty75 is offline
Old April 17th, 2024, 09:36 AM
This is why you do not create three separate threads with the exact same question in three different threads.
Vintage Chief is offline
jaunty75's Avatar
jaunty75 is offline
Old April 17th, 2024, 09:59 AM
Triple threads, really?
Not only that but you resurrected a thread from 2013.
Let me see if I can fix this. Post a pic of that 64 98, STAT! I need to make sure it's not the one I used to own.
Olds64 is offline
Old April 17th, 2024, 10:23 AM
Thanks. Found it.
Marty Webb
January 30th, 2021 08:00 AM
Blackpage
December 21st, 2011 10:41 AM
kimberlies7
August 30th, 2009 12:35 PM
port
September 1st, 2007 01:19 PM
Quick Reply: How can I find vehicle description via VIN# ?
