1962 isnt getting gas to carb
Old April 1st, 2007, 07:42 PM
muttmeg's Avatar
A kid pointed out a rubber cap like piece that draws the gas into the carb, that is cracked what is this part called? He told me and I forgot.
muttmeg is offline
Old April 2nd, 2007, 06:05 AM
Past Administrator
Oldsguy's Avatar
Not sure what you mean. Is this on the carb? The fuel pump is located forward on the engine low, below the a/c compressor if you have a/c, the fuel pump draws the fuel from the tank and pumps it into the carb. I guess you could actually call it a fuel "sucker".
Oldsguy is offline
Old April 21st, 2007, 09:26 PM
muttmeg's Avatar
Unhappy stumped
The fuel pump is fine. The line was clogged from old gas but I think I have that cleared. There is a loop in the fuel line that comes up into the trunk. When I lift that loop, one end is open ended going nowhere. Maybe there was a rubber length that rotted off which extended into the tank? And the fuel filter seems to have fallen off. I cant find any replacement filters on line. I wish I had a picture or drawing that would help me with how this is supposed to be working. Is there a chiltons or similar manual on this? I have a shop manual which has little to no reference to the fuel line, pump or filter other than the latter should be cleaned periodically.
Kate
muttmeg is offline
SD72cutlass
December 7th, 2014 04:47 PM
tds
July 1st, 2014 12:51 PM
69CutlassAlex
May 28th, 2014 10:19 AM
joepenoso
July 19th, 2013 12:44 PM
auto_editor
January 16th, 2011 08:08 PM
Quick Reply: 1962 isnt getting gas to carb
