Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
68 Cutlass
Old March 10th, 2024, 09:06 AM
patg_225's Avatar
68 Cutlass
Good Morning All,
I want to start by saying, the picture really does this car justice. Honestly the car is in pretty good shape. I bought it in 2019.. Been working as a Contractor over the past years spending a lot of time in Iraq, Africa and plenty of other places. I'm back home and I want to do a Full off the frame restoration for this baby here. I'm sticking with the same color. The top is new, recently replaced that. Tires are new, found the wheels on Facebook lol. My main reason for this post is to get a bit of advice. Like I said, I'm going to do a total off frame restoration. I plan on putting this motor in the car ( hope the picture shows). Can you guys point me in the direction for the best rear-end, breaks, control arms, suspension and whatever else I may possibly need to ensure the car can handle this power and ride smoothly. Also, no, I'm not building a race car, but I do want the power, speed and everything else that comes with it. Better to have than not to have. lol. This will most likely be a cruising and car show type of car. Thanks in advance for the tips and recomendations.
patg_225 is offline
Old March 10th, 2024, 10:50 AM
BackInTheGame's Avatar
Sharp ride; I love the color. Sorry, I don't know anything about an engine swap. I'm sure others will chime in.
BackInTheGame is offline
Old March 10th, 2024, 11:02 AM
With that power level, you’re gonna need to massively reinforce the frame on that convertible to prevent it from twisting.
Fun71 is online now
Old March 10th, 2024, 11:05 AM
Rocket Renegade!
Is the engine pictured the one that's in it?
BangScreech4-4-2 is online now
Old March 10th, 2024, 01:07 PM
Bfg
Bfg's Avatar
The color will look good around Halloween
Bfg is online now
Old March 10th, 2024, 03:05 PM
patg_225's Avatar
The engine that is pictured is what I'm thinking about going with. As of now, it is currently LS Swapped with a 2001 5.3L.
patg_225 is offline
Old March 10th, 2024, 03:12 PM
Rocket Renegade!
So "restomod," not restoration, right?
Best of luck.
Old March 10th, 2024, 03:26 PM
Loaded68W34's Avatar
If you can afford that engine, just go with a roadster shop chassis and be done with it. They will build you a frame with brakes, suspension, rear end, and can set it up so the motor will be a direct bolt-in. You can even go full IRS or cantilevered. You will probably be able to get a full pro-touring engineered frame/ suspension for less than the cost of that motor that will out perform anything you can do to your original frame. The link below is 68-72 chevelle.
https://roadstershop.com/chassis-and...8-72-chevelle/
Loaded68W34 is offline
hawks70
June 8th, 2019 09:25 PM
c-towndave
October 10th, 2011 01:34 PM
LaMaR-
October 15th, 2010 12:06 PM
hamrick1229
August 10th, 2009 07:51 AM
Wilson05
February 27th, 2009 10:52 PM
Quick Reply: 68 Cutlass
