3 inch exhaust with an x pipe crossover?
Old March 16th, 2008, 10:55 PM
shaks 442 clone's Avatar
Do you think that will be a good exhaust choice for a 455?
the mufflers will be 40 series flowmasters i already have them.
shaks 442 clone is offline
Old March 16th, 2008, 11:42 PM
dar83501
Guest
Posts: n/a
headers to straight pipe man, headers to straight pipe.
Old March 17th, 2008, 05:02 AM
Rallye469's Avatar
Nothing wrong with an x-pipe, wish I had installed one.
But 3" exhaust seems excessive.
It's money that won't show a return over 2.5" exhaust.
-Pete
Rallye469 is offline
Old March 17th, 2008, 07:49 AM
-Pete
I strongly agree that for a mild 455, 2.5" should be fine. 3" won't hurt anything, but you'll spend more money and have less clearance over the axle. The X-pipe is a very good idea.
joe_padavano is online now
Old March 17th, 2008, 08:03 AM
Past Administrator
Oldsguy's Avatar
I say go with 2.5" pipe, fits better.
Oldsguy is offline
Old March 19th, 2008, 10:38 PM
i dont plan on running tailpipes
currently the car has dual 2 1/4 exhaust with cherry bomb straight throughs that dump a few inches before the axle and i plan on doing the same this if i can with the new exhaust setup
Old March 20th, 2008, 11:18 AM
kaz442's Avatar
I'm running pypes complete(tail pipes also) 3" set up with the X and dumps. This is on a 490 stroker BBO I have run it with the open exhaust and with it closed and have seen no difference in ET or miles per hour. The X does make it a little quieter, helps at the track when they have a noise limit.
The hole set up with hangers and band clamps was $650. Jkaz
kaz442 is offline
Old March 20th, 2008, 11:35 AM
gumbyssfakee's Avatar
i would go with the 2.5 just for clearance issues. i have a 2.5 with a h-pipe and it touches the drivetrain when the car is on a lift but once on the ground everything is all clear. and besides 2.5 is plenty.
gumbyssfakee is offline
Old March 20th, 2008, 12:46 PM
an x pipe quiets the exhaust down? really?
Old March 20th, 2008, 01:09 PM
Past Administrator
Oldsguy's Avatar
The way it has been explained to me is this. It is all about waves of pressure (sound) passing down the pipe, through the muffler (if applicable) and out the tailpipe. Without an X or H pipe, each tailpipe has four waves of sound exiting for a given amount of time. With the X or H pipe, each tailpipe has eight waves of sound exiting for a given amount of time....divided by two. The total amount of sound may be the same because there are two pipes but with twice the sound waves traveling down each pipe there is a cancellation effect. I am not a sound engineer nor do I begin to understand all the mathematics involved in effective exhaust systems. I guess it sort of "smooths out" the total sound of the exhaust. Conversely, if you have ever heard an engine with zoomies each pipe seems to be so loud because the sound is so staccato in quality, of course they are only about 18 inches long too, I guess that helps. Does all this sound weird? Maybe I shouldn't post this. Somebody save me.......
By the way, I had 3" pipes through shorty mufflers dumping in front of the rear axle on the 455 in my 1969 Delta. They were probably too big, I know they were too big to pass over the axle and exit under the bumper. That is why the dumped in front of the axle.
Oldsguy is offline
Old March 21st, 2008, 08:05 AM
The X-pipe helps by allowing each exhaust pulse to "see" both mufflers, so you've effectively cut the muffler backpressure in half. Since the pulse pressure is also split between the two mufflers, you also reduce the sound level. I will caution that ending the exhaust in front of the axle has some problems. First, you're increasing the chances of an exhaust leak getting into the passenger compartment. Second, even if you don't have a leak, the extra heat of the exhaust in the rear axle cavity can accelerate the aging of rubber tubing on the fuel and brake lines (been there, got the t-shirt). Finally, I found that the exhaust noise resonated in the rear axle cavity, making the droning sound even worse at freeway speeds.
Old March 21st, 2008, 09:09 AM
Past Administrator
Oldsguy's Avatar
Whew, Saved. I can attest to the fact about the sound resonating at highway speeds.
Oldsguy is offline
Old March 21st, 2008, 12:34 PM
Rallye469's Avatar
I second that.
I had to cut my tail pipes to actually make room for 325's.
Worst mistake I've made. The sound of my exhaust in the cabin
is annoyingly loud. Even though outside the car it's quieter!
Old March 21st, 2008, 10:02 PM
I don't know if you guys are aware but im 19 years old turning 20 in May and this is the time for me to have a loud muscle car haha.
Old March 21st, 2008, 10:35 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
You will like the loud exhaust, but not the droning.
I'd run open headers before I stopped a pipe before the rear axle again. It was awful, especially in a car with no interior and rotten rear floors. Couldn't hear or breathe Even though it dumped out 90 past the door before the wheel. Didn't make much difference.
It lasted 2 days before I re ran it.
Stick your head in a big stereo speaker box with some Wu Tang playing and that's how your driving experience will be.
J-(Chicago) is offline
Old March 22nd, 2008, 10:10 AM
I'm approaching the 30th anniversary of my 20th birthday, also in May (do the math).
I will admit that things that didn't bother me three decades ago now irritate me (used to be the first thing I did when getting a car was to rip out that heavy A/C - now I'm putting them in...). For example, I'll take Dynomax mufflers over those obnoxious Flowmasters any day (plus, the Dynomax has less backpressure!). Having said that, I'll second the response above - it's not the volume that's the problem, it's the droning that will drive you crazy. I was about 25 when I ran this setup and even then it bothered me.
Old March 23rd, 2008, 02:40 PM
Past Administrator
Oldsguy's Avatar
Wu Tang!!???? Eoooowww!
Oldsguy is offline
Old March 29th, 2008, 09:54 AM
Run to Rund's Avatar
The resonance through the body from dumping exhaust before the rear axle gets annoying and will tire you, even though you might not notice it. Loud is better achieved with bigger diameter pipes and the right mufflers, along with "enough" camshaft. Try Walker 21468 3" diesel truck mufflers. They are straight through, perforated core (louvered cores cost flow), no HP loss, significant noise reduction vs. open headers. Still fairly loud especially when you get on it. I am running 3" exhaust after headers, and 3" Torque Tech tailpipes.
Run to Rund is offline
Old March 29th, 2008, 10:09 AM
I had hooker long tuber headers going into 2 1/4 piping into cherry bomb glass pack mufflers that dumped before the axle i kinda loved it haha
so i think i can live with the dronning
Old March 29th, 2008, 10:56 AM
Redog's Avatar
X pipe FTW.
Have one on the Delta and I love it
Redog is offline
Old March 29th, 2008, 08:31 PM
Originally Posted by Redog
X pipe FTW.
did u have it made by the exhaust shop or did you buy it pre made?
1964super88
September 10th, 2014 02:47 PM
timothypaul
April 17th, 2013 08:35 AM
56Super88
June 1st, 2012 03:18 PM
deadmanscurve
January 27th, 2012 05:22 AM
66f85deluxewagon
January 21st, 2008 11:49 AM
Quick Reply: 3 inch exhaust with an x pipe crossover?
