Hood Stripe Set
Old July 28th, 2022, 10:36 AM
Carsick's Avatar
Hood Stripe Set
I'm looking for a decal or stencil set for my 1969 442/ ram air hood). I can't find them but I'm sure they make them.
Carsick is offline
Old July 28th, 2022, 12:29 PM
69HO43's Avatar
Do you mean a 70 ram air style hood on your 69? Or the stock double hump hood on a ram air 69 with scoops under the bumper?
If you need striping for the fiberglass 70 style ram air scooped hood, try here. They seem to have stencils or black/matte black/white striping as well.
1970-72 W-30 & W-31 Oldsmobile paint stencil / stripe kit (stencilsandstripes.com)
You can use the same place as they also sell the wide stripe kit on the hood bumps on the 69 steel hood, either white or black striping or the stencil.
1969 Olds 442 Stripe Kit - Stencils And Stripes Unlimited Inc.
Personally, I wouldn't use the trunk stripe on the 69 kit at all. Those belong on Chevelles.
69HO43 is offline
Old July 28th, 2022, 01:11 PM
Trunk stripe kit? They sell a trunk stripe kit??? That explains why every Faux-Four-Two has them now.
joe_padavano is offline
Old July 28th, 2022, 01:47 PM
Carsick's Avatar
Definitely no trunk stripes for me! I have a 69 with the stock 'flat hood'. Was there a ram air hood that year? Is it a lot to put a '70 hood on with the trim still lining up in front?
​​​​​​Thanks
​​​​​​Maybe I need a stencil kit and I'll paint them on. The car will be white so I think gold stripes would look good. Maybe an 'Olds gold's type shade?
Carsick is offline
Old July 28th, 2022, 01:49 PM
Carsick's Avatar
Carsick is offline
Old July 28th, 2022, 02:03 PM
Originally Posted by Carsick
That's not the flat hood, that's the "double hump" hood that was used on Cutlass S and 442 models. All F85s (except W31s), Supremes, more doors, and wagons got the "uni-hump" flat hood.
Old July 28th, 2022, 02:07 PM
Carsick's Avatar
I'm glad I know that now? I'm probably going to sell that and get a snorkel/ram air style...do they make one for the 69? What do double hump hoods go for?
Carsick is offline
Old July 28th, 2022, 02:10 PM
Carsick's Avatar
Glad I know that now! What's this one worth? I want to put a snorkel/ ram air style hood on. Do they make them for 69?
thanks
Carsick is offline
Old July 28th, 2022, 02:12 PM
Good 1969 hoods are actually in demand. People have put the 1970 hood on the 1969 cars. I personally don't think it looks right, but that's a personal taste issue.
Old July 28th, 2022, 02:18 PM
Carsick's Avatar
Do you think this would line up? I'll delete the latch and just use the pins....a bit pricey
Carsick is offline
Old July 28th, 2022, 02:25 PM
The pins alone probably won't hold it. Since this is obviously not a factory-correct restoration, consider an all-fiberglass repro. It will be significantly less expensive. VFN Fiberglass and Showcars Bodyparts sell them.
Old July 28th, 2022, 04:47 PM
Carsick's Avatar
My biggest concern is the trim on the grill lining up with the hood trim.is it really involved to make the OEM latch work with one? Thanks Joe
Carsick is offline
Old July 28th, 2022, 05:04 PM
Use the 1969 hood tooth and trim. The stock latch either requires the core support to be swapped or modified to match a 70 or the underside of the metal hood frame to be modified to match a 69.
Old July 28th, 2022, 07:22 PM
Carsick's Avatar
I'll yank the 'tooth' on my current hood. The front clip is off right now. Is it easier to swap in a new core support or mod the one I have?
Carsick is offline
Old April 20th, 2024, 11:34 AM
Chatt's Avatar
Lots of stripes
Chatt is online now
Old April 20th, 2024, 01:06 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
https://phoenixgraphix.com/gm/1969oldsw42.php
PHOENIX GRAPHIX has many Olds strips. Which ever hood you decide to use.
Personally Id rather see the W30,31,32 scoops under the bumper on a 68 69.
droldsmorland is offline
gvermillion
July 11th, 2021 06:47 AM
zekecut70
Paint
March 25th, 2021 08:10 PM
viking blue
September 19th, 2018 12:50 PM
w30hurstolds
Hurst/Olds
March 23rd, 2014 09:39 PM
trucker442
July 24th, 2012 06:42 AM
Quick Reply: Hood Stripe Set
