62 88 steering column needed
Old October 29th, 2019, 07:09 AM
jerbear2's Avatar
I need a non-tilt steering column for my 62 olds -88 . Direction parts shot ,cannot find one ,is there a interchange column from a buick or chev that would work? Any one with a brake down photo of column [ attachment ]
gsretired@outlook.com
Thank You
jerbear2 is offline
Old October 29th, 2019, 08:36 AM
Jebear, I moved your thread and edited the title. Hopefully you get more replies this way.
I doubt a Chevy, Buick, Pontiac or Cadillac column from similar years would work. GM didn't start corporate parts until later. Have you considered an aftermarket column? If you don't have a steering column at all this would get you on the road again.
http://www.flamingriver.com/index.php
https://www.ididitinc.com/
Olds64 is online now
Old October 29th, 2019, 08:57 AM
Phantom Phixer
Charlie Jones's Avatar
Charlie Jones is offline
Old October 29th, 2019, 09:20 AM
jerbear2's Avatar
Steering Column
Thank You for your quick reply. Will help me with questions I have with my column.
Is the photos for a auto.trans? I was told there a difference.
jerbear2 is offline
Old October 29th, 2019, 10:38 AM
Unfortunately, those parts diagrams only give you the group numbers of the parts, not the actual part numbers. You need to look up the specific parts in those groups to know what is common or not. We don't even know what parts of your directional switch are bad. What exactly is the problem that makes you think you need a new column?
In any case, you need to check the listings in the parts book. For example, the Actuator Assembly in the first diagram Charlie posted is unique to the 1961-62 cars and is different for standard trans and automatic. The turn signal switch is common from 1957-1962 on the full size cars and is part number 1998138. Fusick and other vendors have the switch if that is your problem. Without knowing the details of what exactly is wrong with your car, suggesting that you replace the whole column is extremely premature.
joe_padavano is offline
Old October 29th, 2019, 06:52 PM
jerbear2's Avatar
Joe - Thank you for reply, I just got the car & turn lites did not work, so I took a look in column threads are striped & broken so I figured a different column.but maybe not if can find parts.
brokenbroken
jerbear2 is offline
Old October 29th, 2019, 07:31 PM
Phantom Phixer
Please give me the name and group number of the parts you need .
I may be able to tell you which makes and models will have these parts .
Old October 30th, 2019, 03:36 AM
jensenracing77's Avatar
I have a steering column that I believe is out of a 62 but can't remember if it is column shift or floor shift. I can get pictures later today. If it is what you need I would let the entire thing go for $70 and shipping.
It could be out of a 63 but I want to believe they are the same. Either way, I can get you pictures of it and be sure.
jensenracing77 is offline
Old October 31st, 2019, 06:33 PM
jerbear2's Avatar
Thank you for come back I would like photo.
jerbear2 is offline
Old October 31st, 2019, 06:40 PM
jerbear2's Avatar
It is the bearing plate in top photo.
jerbear2 is offline
Old October 31st, 2019, 06:56 PM
Sorry, I forgot about this. If I don't get back to it tomorrow after work you may want to send me a PM. I will remember then. I sometimes miss a post on the forum
Old November 1st, 2019, 05:50 PM
jerbear2's Avatar
reminder
jerbear2 is offline
Old November 1st, 2019, 06:33 PM
Well, Sadly it is the wrong year. I think it is 63 but not sure.
Old November 2nd, 2019, 11:27 AM
Olds Collector
vistacruiser1971's Avatar
1962 Steering column
Hi Jerbear: BTW, I don't think tilt was available in 1962. I think 63 was the first year, maybe just Cadillac. Regards, Trent in Los Angeles
vistacruiser1971 is offline
Old November 2nd, 2019, 07:23 PM
Phantom Phixer
63 was the first year that tilt was available . It was available in all GM makes , but only in the B and C bodies .
Old November 3rd, 2019, 04:53 PM
jerbear2's Avatar
Thank you for trying to help me.
jerbear2 is offline
Old November 3rd, 2019, 04:57 PM
jerbear2's Avatar
I do not need a tilt, Thank you
jerbear2 is offline
Old November 14th, 2019, 12:17 PM
rocketscientis's Avatar
Hav 63 98 conv parts car
Would 63 parts work ?
rocketscientis is offline
Old November 14th, 2019, 07:21 PM
Phantom Phixer
No , the actuator and switch both carry different part numbers for 1962 and 1963 .
According to the parts book .
https://classicoldsmobile.com/forums...dition-131501/
Old November 14th, 2019, 08:49 PM
Hav a 62 f-85 conv parts car as well
Would the parts interchange ??
Old November 15th, 2019, 11:12 AM
Phantom Phixer
No , look it up .
Old November 15th, 2019, 11:19 AM
Olds Collector
62 Steering column
Hi Charlie: Good job, is this a great information sharing site or what? Regards, Trent in Los Angeles
Old November 15th, 2019, 06:00 PM
Phantom Phixer
Thanks also go to David Threet ( 68 RocketAction ) . As he is the one that took the info and put it on a "cloud " ,
Where it could be downloaded by all .
Old November 23rd, 2019, 02:21 AM
John Kenneth Smith's Avatar
Thank You
Don’t know much about cars, but got a bunch of 62super 88 parts. Is this what your looking for?
John Kenneth Smith is offline
Old November 23rd, 2019, 04:26 AM
starfire88's Avatar
Joe, I have the same issue in my '62 starfire but the actuator cam is actually physically broken. I think the
part # for the entire actuator assy is: 5674851. Would you know who carries this? I've
been looking , but no luck yet. Much appreciate any leads/info.
starfire88 is offline
Old November 23rd, 2019, 10:11 AM
Olds Collector
Hi John: I am not sure the late model steering column will work for Jerbear2. The dash already has the indicator even though "R" is the last selection not next to the "Park" location like in modern cars. Part of the charm of the older cars is to have the key on the dash where it belongs. Nice to have them moved on to the dash in late model Intrigues and Aleros. Plus the late model column has the interlock for the steering which might be a problem since it is not common on a 62. Regards, Trent in Los Angeles
oldscs
May 26th, 2015 05:21 AM
68conv455
November 19th, 2011 07:36 AM
grt05
April 5th, 2010 08:48 PM
Kidcutty
January 19th, 2010 06:35 AM
souldoubt1
November 6th, 2005 10:22 PM
Quick Reply: 62 88 steering column needed
