i need advice on a 455 build, that i want to build for bop shootout
Old April 23rd, 2013, 07:39 PM
wildwillie1981's Avatar
ok guys heres what I have
69, 455
stock small valve c heads
ofenhauser intake (like the torker)
3500 stall
26 in slicks
60 olds dynamic (4000lbs) without interior and stuff
either 373 or 410 gear
question is is it possible with the right cam and combo... to make it a low 13 or high 12 second car?? usings stock shortblock and heads?
any help is appreciated, thanks
wildwillie1981 is offline
Old April 23rd, 2013, 08:28 PM
70Wcars's Avatar
Yes. The Olds 455 will respond well to the right Camshaft. Let me build you a Q-jet for it, and let's see what we can do about some compression. Also look at Headers to fit that car. But it may not be ready for our Mayy 11 BOP shootout. Come on out and watch and meet us and plan to race this Summer and make the Fall BOP.
Danny
70Wcars is offline
Old April 23rd, 2013, 08:50 PM
hey danny I met all yall olds guys a couple years back at the track.....probably will not make either may or October with the olds.... but should make it with my 70 lemans...lol...im a gm guy but olds is what got me started building and collecting muscle cars.... I still have my first musclecar my 69 olds cutlass, but got it stored for restoration......anyways what is the true comp ratio on the 69 455?......also whats max lift with shims on the stock rockers?.....also what do u think about the olds 328/348 factory olds cheater race cam?
Old April 24th, 2013, 04:14 AM
cutlassefi's Avatar
You can do better than the cheater cam. There are lots of options.
If you're sticking with the stock rockers then obviously you'll need to limit the lift to around .500 and stay less aggressive on the lobe profile.
I have both flat tappets and rollers that will work with the stock stuff.
Compression will depend on what that 455 came out of, could be approx 9.0:1 or 10.0:1.
cutlassefi is offline
Old April 24th, 2013, 06:11 AM
70Wcars's Avatar
I ran the 328/348 Cheater in Big Red for years with small valve C heads and 9.0 to 1 compression. I liked it...ran 11.40 best, but unless you are building a class legal Stocker, then I agree with Mark and try to get a more modern profile with less .050 duration. I also like Bullet's Ultradyne cams...ran one that was 226 In 233 Ex with a .499 lift. very strong cam in a streeter.
Make sure you come see us on May 11 at the track.
Danny
70Wcars is offline
Old April 24th, 2013, 04:19 PM
thanks guys....I just figured the cheater cam would sound( cool) and still work with stock rockers.....ive looked at comp cams and stuff and 268 is about all I can go, because of lift.....wouldn't sound that good.....
now my problem is comp ratio.... I cant figure out which I have 9 or 10 to one
I looked at the oil tube its 8001390, which is 68 I guess
block is 396021f which is 68-72
still doesn't tell me comp.... the motors original color is (red)
so my next question is... how do I find out the comp ratio? is there another casting number that will help find out
AK71CutlassS
May 14th, 2014 08:00 PM
SBORule
October 17th, 2012 08:08 PM
sicky olds
May 11th, 2012 06:21 PM
ACID64
October 19th, 2011 09:28 PM
sicky olds
September 4th, 2011 06:46 AM
Quick Reply: i need advice on a 455 build, that i want to build for bop shootout
