Should I keep the 307 or uprgrade to 350
Old February 3rd, 2009, 07:15 PM
gscott819's Avatar
Question Should I keep the 307 or uprgrade to 350
Just found out that the 1980 Cutlass that I have is a 307,should I keep it or get a 350.Thanks
Oh another thing any suggestions on this car would be great far as headers,exhaust,intake,etc.
And a good place to get some parts would be very helpful.
gscott819 is offline
Old February 3rd, 2009, 10:07 PM
Go to the 350. Eveything on your 307 will bolt up to the 350 also. 307 isn't worth upgrading
Get new motor mounts for your 1980 Cutlass, not the kind of car the 350 comes out of. All SBO are externally the same
Easy swap
Old February 4th, 2009, 04:24 AM
I agree with Redog. A 350 will be much better than a 307. Check out Summit for parts.
Old February 4th, 2009, 05:04 AM
X3 on the 350
Old February 4th, 2009, 05:37 AM
X4 on the 350. Ya gotta post pictures too. We have to see the ride
Old February 4th, 2009, 08:53 AM
ate glue as a child
jaysun's Avatar
x5 on the 350. Look for an 72 or earlier engine, or at least early heads. The chamber size on 73 and latter heads got huge and will result in a poor compression ratio.
why not go with a 455. it's only a little more money to build.
jaysun is offline
Old February 4th, 2009, 09:15 AM
f-85's Avatar
X6 Get the 350.
f-85 is offline
Old February 4th, 2009, 09:45 AM
gscott819's Avatar
Thank you all for the input,What would I have to change to put the 455 in the 1980 Cutlass.I will post some pics later.
Old February 4th, 2009, 12:26 PM
ate glue as a child
jaysun's Avatar
iirc a 455 will drop right in. you need to get the engine with the accessory brackets , the exhaust manifolds and the crossover pipe as they are different. Im sure someone will chime in on which headers would fit the best. Also if you run headers on either engine you will probally need a double hump crossmember. summit and others have them
jaysun is offline
Old February 4th, 2009, 01:06 PM
Nobody suggested the 403?...would be my choice if I wanted to keep it a small block.
Oldsmaniac is offline
Old February 4th, 2009, 02:38 PM
403s are excellent motors as well. They are just a little bit harder to find than a 350.
Old February 5th, 2009, 12:44 AM
You just have to watch the height and width on a 455.
a 455 is 2 inches higher and 2 inches wider than the small blcok
Old February 6th, 2009, 02:34 PM
gscott819's Avatar
Cool 1980 Olds Cutlass
Old February 8th, 2009, 12:41 PM
I think I might have a full set of "clip on" center caps for those Oldsmobile wheels if you are interested.
Old February 8th, 2009, 02:46 PM
gearhead1218's Avatar
350 would be the easiest to swap in.
Love the velour interior.
gearhead1218 is offline
Old February 8th, 2009, 03:03 PM
csstrux's Avatar
As long as the car runs and drives, use what you got. When the pup finally give up the ghost...Thats another story. There is nothing wrong with a small engine in a daily driver, done right a 350 will outperform a 307 any day probably with better economy. the only 307 I've ever ran was an odd duck Chevy, and that info came from the previous owner of an early '70's truck, I never confirmed it.
csstrux is offline
Old February 8th, 2009, 04:00 PM
gscott819's Avatar
Center Caps
yes I would be interested in them,How much??$$
Old February 8th, 2009, 04:06 PM
csstrux's Avatar
After looking at the pics, I'm guessing that unit is a project already, if so then I recant last post and vote 350 or 403 if you can find one. Nice ride don't see too many of those around here anymore.
csstrux is offline
raw442
May 29th, 2013 07:51 AM
timothypaul
May 30th, 2011 11:57 AM
Mr.Cutloose
July 30th, 2009 02:51 PM
thorpedo91
December 21st, 2008 07:41 PM
Quick Reply: Should I keep the 307 or uprgrade to 350
