Changing out the starter?
Old January 6th, 2010, 07:00 AM
Dave in MN's Avatar
Question Changing out the starter?
New guy here, but have been lurking for months. I've always done most of my own repairs (except for rebuilding motors/transmissions), and was a mechanic for many years, so I pretty much know my way around vehicles.
I've got a '97 Aurora (newest vehicle I've ever owned). The starter went out yesterday (grinding noise big time). I don't think its damaged the flywheel because its not 'that kind of grinding'.
Anyways, have any of you guys and gals changed out your starter, and how much of a pain is it?
I found a repair manual online and ordered it, so that'll help once it gets here.
Thanks.
Dave in MN is offline
Old January 6th, 2010, 07:03 AM
I've never done maitenance on a late 90s Aurora. It shouldn't be too difficult. Good luck. Please keep us posted.
Old January 6th, 2010, 07:57 AM
Originally Posted by Olds64
I've never done maitenance on a late 90s Aurora. It shouldn't be too difficult...
Yeah, well, except for the fact that the starter is in the valley under the intake. Fortunately it's pretty easy to remove the intake on the Northstar family and the gaskets are o-ringed and reusable. The hardest part is disconnecting all the quick-connect fuel line fittings. You definitely need the special disconnect tool set.
Old January 6th, 2010, 10:56 AM
Oh darn! Looks like someone might have to turn a wrench!
Old January 16th, 2010, 02:59 PM
Dave in MN's Avatar
Well, it wasn't as bad as me & my son thought it would be...........
Had to pull the entire intake, fuel rails, yada, yada, yada........
Here's a pic of it once everything was ready to be put back together. It took about 2 1/2 hours to change the starter.
Old January 19th, 2010, 02:48 AM
Yellowstatue's Avatar
Thanks for the pic ...I am expecting to have to open my '99 up in the near future...starter clicks a few times before engaging...
Yellowstatue is offline
Old January 19th, 2010, 07:38 AM
I hope you desludged the throttle body and fuel injectors while you were doing this repair. If not then that was a golden opportunity missed. This simple procedure can greatly improve idle performance and gas mileage.
Old March 27th, 2010, 05:30 AM
Dave in MN's Avatar
We did that last weekend when we tore it apart again. It runs a bit smoother than I remember.
Old July 21st, 2010, 03:02 AM
inthedirt's Avatar
I had to do our starter on New Yearls Day when it was 18 degrees out. I agree with everything above and would add that the trickiest part is getting the manifold to clear the power steering pump.
inthedirt is offline
Old July 21st, 2010, 03:08 AM
firefrost gold's Avatar
thats crazy a starter in the intake I would have said you were on crack.
firefrost gold is offline
Old July 21st, 2010, 05:29 AM
They do all sorts of odd things on cars these days.
Old July 21st, 2010, 06:04 AM
Dave, can you post some more details when you get a chance, like what tools you used to disconnect the fuel lines and anything else that is 'strange' or unexpected?
I fear i will have to do this on my 97 Caddy some day. I bet the dealer will want half a grand to do it.
I have only changed the belts & coolant hoses on that beast, and that was bad enough - 8 hours total!
A starter IN in the engine - I think the designers were on crack...
Another reason why i do not want another 'modern' car.
Old July 21st, 2010, 08:43 AM
inthedirt's Avatar
The only special tool you need is to disconnect the fuel lines. The tools are cheap and come in plastic or metal. Buy a kit that covers multiple fuel line sizes to be sure you make only one trip to the store.
This is an example of what one looks like but they come in a couple of different styles. You do not need a flare nut wrench if someone at the store tries to sell you that as this tool is for a different application and will not help you.
http://www.amazon.com/OTC-6603-Fuel-.../dp/B000JFHNME
Tedd Thompson
March 21st, 2015 01:32 PM
Redog
July 23rd, 2012 11:56 PM
skryla
December 25th, 2011 07:36 AM
Ddbord
July 1st, 2011 02:39 AM
pgcolvin
October 19th, 2010 10:32 AM
Quick Reply: Changing out the starter?
