Canister Purge Solenoid 3800 V6
Old April 2nd, 2010, 12:59 PM
Joeypete's Avatar
I'm getting a CEL on my 90 Toronado and from running the onboard diagnostics I think I've discovered that the canister purge solenoid is not working.
Problem is I am not sure where it is!! Does anyone know? I know what it looks like but I can't see it anywhere.
Any help would be appreciated.
Thanks!
Joeypete is offline
Old April 2nd, 2010, 06:50 PM
70 cutlass s's Avatar
I'm thinking on this car its on the top of the vapor canister.
If it is not on the top of the canister then it will be located on the intake mounted to a bracket with a vacuum line going to it and one running from it to the canister. I would check the vacuum lines first that might be the problem.
I have a couple of pics that should help you.
70 cutlass s is offline
Old April 3rd, 2010, 07:35 AM
Joeypete's Avatar
Thanks Andy! I just got my service manual in the mail yesterday. You are right, it is on the top of the canister. I have to take off the air cleaner assembly and relay center to get to it, but from what I can "feel", I think the wire connector broke off. It has a wire that runs to the ECM...if it did break, that would be why the CEL is going off. Now I would have to just figure out how to fix it!
Joeypete is offline
Old April 3rd, 2010, 07:56 AM
Maybe it won't be to bad. Worst case if you needed a connector. You can go to a junk yard and get connector off any GM that has the purge valve on the canister. Take a pic of your before you go looking so you make sure you get the right one, but I thinking they all shared the same connector at least something around the same year. Not a 100% sure. So take a pic or take it with you.
I hope yours is a easy fix.
Old April 3rd, 2010, 08:08 AM
Joeypete's Avatar
Thanks...hoping it's easy too Luckily it's not something that is causing drive-ability problems...but still, I want it fixed.
Joeypete is offline
Old April 5th, 2010, 10:44 PM
Joeypete's Avatar
I got to look at it today. It appears some pack rats got into the engine compartment at some point...the wires were chewed right off...and naturally right at the connector. I bought some 18 gauge wire and new terminals...had to take the connector apart then splice the new wire to the old with butt connectors. It worked! No more SES light!. Damn rats!
Joeypete is offline
Redog
November 7th, 2013 05:58 PM
Joeypete
June 5th, 2010 08:11 PM
85LS
March 2nd, 2009 12:38 PM
Allan R
September 13th, 2008 09:22 PM
Quick Reply: Canister Purge Solenoid 3800 V6
