Canister leaking charcoal?
Old April 22nd, 2010, 01:44 PM
oldzy's Avatar
oldzy is offline
Old April 22nd, 2010, 03:00 PM
Gary
Gary's 2 442-S's Avatar
I don't think that the charcoal should be coming out. I just found one this past weekend at a wrecking yard and nothing is coming out of it. The one that came with the car, the charcoal is not coming out of it either. maybe the one you have is damaged in some way.
Gary's 2 442-S is offline
Old April 22nd, 2010, 08:21 PM
OldCar_Mechanic's Avatar
The Evaporation Control System (ESC) is designed to prevent fuel vapors from vehicles fuel system from entering into the atmosphere. The fuel system is closed with a normally sealed fuel tank filler cap and a vent system is provided through which fuel vapors are conducted through a vent line to engine compartment where they are burned in the engine.
The Charcoal Canister is filled with activated charcoal which absorbs and stores fuel vapors when the engine is not running. The one you show is used on all General Motors V-8 engines (except Chevrolet). The canister has two hose connections on it's top as you can see. When the engine is running, air is drawn in through the bottom of the canister. This air picks up vapors which are being held by the charcoal and carries them through the carburetor into the engine where they can be burned. This action purges and renews the absorbtion quality of the charcoal.
The filter should be replaced at 12,00 miles or 12 months. Disconnect the hoses from the top and remove the canister. Remove the cover from the bottom of the canister by pulling it down to disengage the clips (most of which are usually missing after time). Remove the filter and install a new one. Make sure that the element is in under the retainer bar evenly and tucked under the canister lip. Snap the bottom cover back on and reinstall the canister and reconnect the hoses.
Now your canister shows that the filter is not there. It should fit in that space between the bar and the grid that you see. The other piece of foam like material that you see is another filter to keep the charcoal from falling out. The filter that is missing, filters the debris in the incoming air. That filter that you see in yours is torn and I don't think you can replace that one without destroying the canister.
Hope some of this helps.
Ron
OldCar_Mechanic is offline
Old April 22nd, 2010, 08:36 PM
oldzy's Avatar
Thanks for the info. Sucks if I can't take it apart to fix that inner filter. I put a piece of scotch tape over it for now.
It seems I am missing several pieces...
1) very bottom filter
2) bottom canister cover
3) metal housing and screws
oldzy is offline
Old April 23rd, 2010, 05:47 AM
Wow - I have never seen one leak charcoal, even with no filter on it.
I would take it up with the one you bought it from - he should replace it.
I never knew these could be rebuilt successfully.
Old April 23rd, 2010, 09:06 PM
oldzy's Avatar
I don't get it then. If it had no filter... how could charcoal NOT spill out?
oldzy is offline
Old April 24th, 2010, 07:21 AM
The replaceable filter is just a flimsy see-thru fibreglass disk, like you would cut out of those cheap furnace filters.
The charcoal itself is contained in some other kind of other 'filter bag'.
I need to crack open a cannister some day to see its guts...
Old July 1st, 2013, 03:24 PM
ddd777's Avatar
Question Can Vapor Canister Be Rebuilt?
Originally Posted by Lady72nRob71
Wow - I have never seen one leak charcoal, even with no filter on it. ...
So can these things be rebuilt, or do I need to find a replacement?
I can't figure out how to get it open without destroying it.
Mine is leaking charcoal as soon as the little filter is picked up (see attached).
ddd777 is offline
Old July 1st, 2013, 03:33 PM
What's your objective? Is this a 100-point restoration?
If not, I'd just leave it in there in whatever condition it's in and ignore it.
Maine doesn't check emissions on antique cars, and even in Cumberland county, where the test emissions on modern cars, they don't test evaporative emissions.
Old July 1st, 2013, 04:21 PM
ddd777's Avatar
I just figured it has some function, and don't want hoses that go nowhere in the engine compartment. Already have a couple of those that I am working to resolve.
Saving the 100 point restoration for my next one ;-)
So do you recommend that I shake the loose charcoal out, stick the new filter in at the bottom, and call it a day?
Maine doesn't check emissions on antique cars, and even in Cumberland county, where they test emissions on modern cars, they don't test evaporative emissions.
Ah, Maine, the way life should be....
Thanks for your suggestions.
ddd777 is offline
Old July 1st, 2013, 05:29 PM
I wouldn't shake anything out of it, I'd just check it to be sure that there are no leaks where there shouldn't be any (and, no, I have no idea where it should or should not leak - I've just always ripped them out and thrown them away).
Old July 1st, 2013, 06:10 PM
Sampson's Avatar
Mine is leaking too. Started when I removed the bottom filter to clean the unit. Can you buy the replacement filter mat? I was going to cut up a piece of furnace filter mat and stick in there. I am going after an original look but really do not care if it works or not.
Sampson is offline
Old July 1st, 2013, 06:55 PM
The little fibreglass filter used to be sold at auto parts stores. I have a new fram one in the package from LONG ago. For the cost I would just find a substitute.
rhett838
July 24th, 2015 12:23 AM
jbestic
March 26th, 2012 08:02 PM
frasco
August 1st, 2011 09:25 PM
texasred
May 14th, 2011 06:04 AM
esisson
November 23rd, 2008 10:05 AM
Quick Reply: Canister leaking charcoal?
