Vintage Oldsmobiles Curved Dash, Limited Touring, Models 40, 53, 66; Series 60, 70, 90
turn signal cancel cam
Old May 19th, 2010, 09:35 PM
jaymann's Avatar
I hope I'm not over doing it with all the questions lately!
My turn signals don't shut off after making a turn.
I pulled the steering wheel off, and must be missing something?
Here's a pic...All I did was pull the horn ring off and then the steering wheel...
What's missing here?
jaymann is offline
Old May 20th, 2010, 03:10 AM
Yellowstatue's Avatar
On the later wheels there are two circular spring clips with a single turn that are wound opposite to each other that sit on each side of the centre tab and cancel the sig when the wheel returns...they are fully visible and yours are not --hope this helps...
Yellowstatue is offline
Old May 20th, 2010, 05:56 PM
Are you sure the car has auto canceling turn signals? From what I understand that was an option in the 50's and didn't become standard until the early 60's.
But I'm just a "young pup" so please don't take this as gospel.
Old May 20th, 2010, 07:37 PM
jaymann's Avatar
I asked on here before and the general consensus was that they do auto cancel.
You can see in my pic there's 2 "hooks" on the upper and lower left side of the column that looks like it would hold something
jaymann is offline
Old May 24th, 2010, 10:38 PM
Just stumbled upon your spring, clumsy me, group 2.916, PN 1929964... a flat spring with a hook at each end and a 'W' shape in the middle. It might have become dislodged and dropped down the inside ot the steering tube... sits on the right side of your pic with the square edge up against the 'W' part of the spring, hooks on ends facing inward... Upon further investigation (actually I looked at the other spring you are missing) ...so the cancel spring is round wire and sits on the left side of the pic with the two ends of the spring engaged in those two holes you mentioned Group 2.910 PN 1929955- book calls it a [Spring, release coil 1955-57 all] the other flat spring for the right side is a detent spring...
Last edited by Yellowstatue; May 24th, 2010 at 10:49 PM. Reason: Flash of intense pain!
Old May 25th, 2010, 08:57 PM
jaymann's Avatar
thanks Yellowstatue...now I know what I'm missing, I just have to figure out where to get them!
jaymann is offline
70 ctls
November 23rd, 2019 08:07 AM
eddieunderground
February 22nd, 2013 08:17 PM
eddieunderground
February 22nd, 2013 06:56 AM
eddieunderground
February 18th, 2013 04:25 PM
64Todd
June 24th, 2011 10:11 AM
Quick Reply: turn signal cancel cam
