Alternator change to internal regulator
Old September 7th, 2010, 10:28 AM
One of None W-31
71 Cutlass's Avatar
Was told if I went to the one wire alternator with internal regulator, that my "GEN" light would not come on if I ever needed to be warned of an alternator problem. Which wire goes to the "GEN" light, and is there another wire I can just splice it onto to keep the "GEN" light working? Still have external volt. reg. hooked up till 6pm tonite when I change it, so any posts before then that can comment on the use of those wires (if they are cogent to this discussion) would be great.
Thanks.
71 Cutlass is offline
Old September 7th, 2010, 01:54 PM
same but different
don71's Avatar
Can't help you very much, but the idiot light used the brown wire that came from the external voltage regulater in 1971.
I know of no way to use the one wire alt. with the idiot light.
don71 is online now
Old September 7th, 2010, 01:57 PM
Thanks.
Don't use a one wire alternator. The normal three wire 10SI uses the #1 wire from the plug to operate the GEN light. It also uses the GEN light to turn on the alternator at idle. One wire alternators typically do not turn on and start charging until RPMs exceed 1500. I am especially amused by the fact that the aftermarket has convinced everyone to use a one-wire alternator (which eliminates the GEN warning light) and now at least one aftermarket wiring vendor is selling a solid-state add-on device to restore the warning light function. Pay extra to remove it and pay again to put it back.
Or, you could save all that money and just wire up a stock 10SI that you can get repair parts for at any auto parts store.
Old September 7th, 2010, 10:30 PM
One of None W-31
71 Cutlass's Avatar
I am using the 3 wire alternator as suggested(original hot wire and has a pigtail for GEN light and and second hot wire conection). Just installed it tonite...GEN light works....no problems. Only weird part was that when I pushed the "tab" on the inside of the alternator to set the polarity, I might have pushed too hard b/c it sounded like my screwdriver went through a buzz saw. Anyway, no ill effects after starting and test driving.
Old September 8th, 2010, 09:45 AM
Only weird part was that when I pushed the "tab" on the inside of the alternator to set the polarity...
You don't "set polarity" on an alternator. The hole and tab are only there for diagnostics. Normally you don't do anything with them.
Old September 8th, 2010, 09:55 AM
One of None W-31
71 Cutlass's Avatar
I thought it was weird, but was told to do so by the salesman, and called an Olds guru in CA to confirm and he also said yes. Anyway...who knows with all this new fangled equipment.
Old September 15th, 2010, 07:59 PM
Just the facts...
BILL DEMMER's Avatar
you need a new guru! lol
joe is correct, you don't polarize an alternator.
when you pushed the screwdriver in, it met up with the spinning rotor, you probably didn't do any damage to the alternator, just took off the coating on the rotor which will now rust.
bill
BILL DEMMER is offline
Old September 23rd, 2010, 05:58 PM
2oldsguy's Avatar
When you insert a small screwdriver or any small metal rod into the D shaped hole you should hit a small tab on the regulator. When you touch the tab you then let the shaft of the screwdriver touch ground and you will bypass the regulator and full field the unit. It was a quick way of testing the alternator only, if it charged when grounded then you would replace the regulator.
As for the buzz saw, it was very common, you went past the tab and hit the rotor. No harm done.
Joe
2oldsguy is offline
Old September 23rd, 2010, 07:32 PM
One of None W-31
71 Cutlass's Avatar
Joe,
Thanks for your informed response. It was indeed a "D" shaped hole. Everything has been working great since the installation, just was a little more excitement than anticipated.
J-(Chicago)
July 14th, 2014 07:36 AM
dfire25
May 29th, 2013 08:06 AM
yeahbuddy
December 1st, 2011 10:29 PM
danlonchar
October 2nd, 2010 12:34 PM
1970_442
July 8th, 2010 03:30 PM
Quick Reply: Alternator change to internal regulator
