2001 alero transmission fluid level
Old April 17th, 2007, 04:40 PM
asadebo's Avatar
Question 2001 alero transmission fluid level
Hello everybody ,somebody know how to check that the transmission fluid is in level on an alero 2001 automatic? thanks !
asadebo is offline
Old May 3rd, 2009, 03:29 PM
vettelover8181's Avatar
With the car raised and level; there is a 7/16 bolt on the passenger side of the transmission inward of the right axle. Remove it slowly. If the fluid runs out it's full. Make sure it's not overfilled. If no fluid comes out; fill it slowly till it comes out then stop filling and insert the bolt and retighten. The transmission cap is on the top under the exhaust crossover pipe on the driver's side. It is usually red in color. This is best done with two people. One filling and one under the car. Hope this helps.
vettelover8181 is offline
Old May 3rd, 2009, 04:57 PM
man what a crazy way to have to check the tranny fluid. The designers were really on the ball with that one.
Old May 3rd, 2009, 05:26 PM
csstrux's Avatar
I think he is assuming a manual trans. Under the hood you SHOULD see a little red handle roughly in front of the drivers seat back by the firewall. That should be your stick for the trans. I have an impala, but basic layout should be similar.
csstrux is offline
Old May 3rd, 2009, 08:35 PM
^ No
The Impala has the 4T65 Transmission and the Alero has the 4T45 Transmission. The 4T45 has no stick. However the location of where it should be is correct. There is a red cap just under the air cleaner box and the exhaust crossover like VetteLover said
Yes the way VetteLover put it is the correct way to check the tranny fluid on the 4T40/4T45 transmission since it has no dipstick, however I thought the bolt was 11mm.
The car also has the be running and the engine and tranny hot when doing this, the car also has to be on a level surface for this to work correctly
Hairy Olds
February 22nd, 2013 02:55 PM
dannyb
August 11th, 2011 07:46 AM
Snowdog
June 8th, 2009 12:10 PM
cfair
June 8th, 2009 12:37 AM
wment
Alero
December 28th, 2006 02:30 PM
Quick Reply: 2001 alero transmission fluid level
