Oldsmobile engine specs...check this out!!!
Old April 7th, 2011, 09:53 AM
1965cutlassragtop's Avatar
i don't know if anybody has presented this chart before, but it lists all the factory specs, horsepower, torque, timing, etc. very cool!!! i got some info i had been looking for for a while from this chart, hope it helps someone else on here.
http://www.carnut.com/specs/gen/olds60.html
1965cutlassragtop is offline
Old April 7th, 2011, 10:19 AM
Diego's Avatar
It would be a hell of a lot cooler if we knew it to be accurate. I picked one omission already.
Diego is offline
Old April 7th, 2011, 10:24 AM
Got wood? I do! (an '89)
auto_editor's Avatar
Come on now. Don't let a little thing like accuracy ruin it! Just look at that formatting!
auto_editor is offline
Old April 7th, 2011, 10:27 AM
Diego's Avatar
I can't claim to be an expert on these things, but the 400/325 is missing for 1968.
So while the format may be dandy, I'd have to go over the thing with a fine-tooth comb and an accurate resource to know whether it's a reliable compilation of data.
Diego is offline
Old April 7th, 2011, 10:30 AM
typical car enthusiasts....always pointing out what's wrong, looking past what's right. these people are the reasons i don't like going to car shows.....so what is wrong diego???
Old April 7th, 2011, 10:32 AM
Diego's Avatar
I've already stated one thing I've noticed. Sorry to hear that you are not pleased with my opinion.
Diego is offline
Old April 7th, 2011, 10:37 AM
so they left out some engines....okay, can anyone find anything wrong with the specs on the engines they do list?? like, is the timing wrong?? are the horsepowers wrong?? torques wrong?? i'm just trying to determine if this is worth taking into consideration. i have been looking for specs on my 330 for a long time, and havn't been able to find anything this detailed. maybe whoever made this chart couldn't confirm some information in the 68 400/325 motors u mentioned?? just a thought...
Old April 7th, 2011, 10:41 AM
Diego's Avatar
If you have a good resource to double-check information, by all means be my guest. I just happened to notice one omission. Was it overlooked? Was it due to sloppy research? I don't know, which is why if I was using the info for my own purposes, I'd try to find other resources to verify. There's plenty of misinformation floating around the Internet and my bookshelves for me to totally rely on someone's hard work.
Diego is offline
Old April 7th, 2011, 11:01 AM
Diego's Avatar
The issue is that I noticed one engine was missing. Maybe there's someone here who can answer your question - hopefully they're less typical car enthusiasts.
Diego is offline
Old April 7th, 2011, 11:10 AM
Seff's Avatar
One engine missing is better than inaccurate or dubious info being present about that engine.
Seff is offline
Old April 7th, 2011, 11:17 AM
Diego's whole point is that if there is even one known error in the list, how many other entries are in error? Mistakes make me skeptical.
Originally Posted by 1965cutlassragtop
i have a 65 330, 4bbl.....can you get me the specs on this engine? for example, did it use a forged steel crank from the factory?? what was the factory compression?? and what RPM should the redline be set at??
The best source of that info is the factory Chassis Service Manual for your year. All 1964-1967 Olds V8 motors did use forged cranks.
Old April 12th, 2011, 07:58 AM
Diego's Avatar
1965cutlassragtop, any reason why you deleted your posts?
Diego is offline
Old April 13th, 2011, 03:04 AM
45 yrs of Olds Nuttiness
jrzybob442's Avatar
Chassis Service Manuals, Factory Assembly Manuals, Factory Inspector's guides and Factory AMA Specs - all which list the ACCURATE specs for the vehicles can be found at http://wildaboutcarsonline.com/cgi-b...=9900334159517
All are downloadable PDF files.
jrzybob442 is offline
Old April 13th, 2011, 03:55 AM
Nilsson's Avatar
Guy thinks he is helping out his fellow Oldsmobile enthusiast and gets kicked in the teeth.
Sometimes it is best to say nothing or keep your opinions to yourself.
Nilsson is offline
Old April 13th, 2011, 04:20 AM
I somehow missed this thread. Looks like it must have been interesting...
The larger of the two tables in question looks to me like it is scanned (or typed?) from a 1969 Chilton manual. I'd have to go dig mine out to be sure, but they cover the entire range of American cars, span the previous ten years, and have tables that look just like this. I've always kept a small collection of them (they tend to be less than $5 at flea markets) to use "in case of emergency" if I drag home an old car I've got no manuals for.
I guess now with this thing called the internet I don't need them anymore.
Old April 13th, 2011, 05:11 AM
TK-65's Avatar
64 442 330 315hp is not on there either.
TK-65 is offline
Old April 13th, 2011, 05:26 AM
jrzybob442's Avatar
The problem with any list compiled from other than factory sources is the opportunity to "lose" an entry. These lists are handy references, but will never be as accurate as the original materials.
We even have them at WAC, but for accuracy, always try for the factory specs. If you guys have never seen the Factory submissions to AMA, you ought to check them out, because, they are quite detailed. The only thing they might miss is somethig issued after the submission, though the manufacturers were supposed to update their info.
The specs for 1964 through 1972 can be found at: http://wildaboutcarsonline.com/cgi-b...=9990359910558
Old April 13th, 2011, 06:37 AM
Me, personally appreciate any and all info!! What works for one person may work for others. I've got motors manuals from the 1960 - 1975, and believe me, they are plagued by errors.
I want to thank 1965cutlassragtop for his input, and in no way want to see anyone discouraged in the future for bringing in new info!!!!!
oldcutlass is offline
Old April 13th, 2011, 10:08 AM
Diego's Avatar
I guess it all depends on who you consider the one doing the helping, and what is considered "getting kicked in the teeth," right?
Diego is offline
The_Jeremiah
June 29th, 2013 10:36 PM
BIGJERR
September 5th, 2012 04:33 PM
J-(Chicago)
January 6th, 2008 12:36 PM
sean000
January 31st, 2007 05:03 PM
69cutlassgirl
April 25th, 2006 04:44 PM
Quick Reply: Oldsmobile engine specs...check this out!!!
