1968 Olds Cutlass S Intake Manifold
Old April 8th, 2011, 02:39 PM
1968 Olds Cutlass S
jdana24's Avatar
Can someone let me know what the correct casting number would be for both a 1968 Olds Cutlass S Rocket 350 with a 4 barrel carb; and the same info for a W31 intake manifold for a 1968 Ram Rod?
jdana24 is offline
Old April 11th, 2011, 03:52 PM
1968 Olds Cutlass S
jdana24's Avatar
For the archives, I found out that for a 1968 350, no matter whether Std. 310 HP
or W-31, they used the same intake manifold, casting number 398663.
jdana24 is offline
Old June 26th, 2012, 05:07 AM
Chesrown 67 OAI's Avatar
Same casting is used on a 69 350 also but the 68 only has "divorced" choke. 69 has choke tubes to choke on carb!
Chesrown 67 OAI is offline
Old June 26th, 2012, 10:38 AM
Uh, no. The 68-69 cars all used the same intake and divorced choke. The manifold doesn't have the provisions for the tubes for the integral choke. They have the cast-in pocket for the bimetallic coil. The 1970-up cars used the integral choke and the intakes had the provision for the tubes.
Old June 26th, 2012, 01:16 PM
Say it aint so - Joe!!!
Old June 26th, 2012, 02:49 PM
Dave Siltman's Avatar
Tweed, I hate to tell you, but Joe is right (again) on this one. '70 started the tube style.
Dave Siltman is offline
Old June 26th, 2012, 06:53 PM
Ok. the ones i looked at in lansing musta been 70s??
now i know i have the right one for my 68 project. That was my main purpose?
Old June 27th, 2012, 01:36 PM
jerseyjoe's Avatar
Jeff,
I checked my intake, it is the 398663 casting, 68 4bbl from cutlass S.
Archives are correct.
Joe
jerseyjoe is offline
shamusj
December 18th, 2014 09:28 AM
dster69442
February 20th, 2012 05:41 PM
svnt442
July 17th, 2011 04:43 PM
gnoto
February 9th, 2008 01:33 AM
magnusdog
September 2nd, 2006 10:01 PM
Quick Reply: 1968 Olds Cutlass S Intake Manifold
