Posi rear end
Old April 20th, 2011, 10:10 AM
Deedsntitles's Avatar
Posi rear end
looking for a decent used posi rear end with gears ranging in size from 3:73 to 3:08. This will be for my 1972 cutlass. 10 or 12 bolt doesnt matter...just want axle to stay the same width so prefer type O
Thanks!
Deedsntitles is offline
Old April 21st, 2011, 06:09 AM
Bob Kelso's Avatar
I have a 3;23 posi - 10 bolt rearend out of a 71-72 A body , it is the bolt in style o- axle set up . Ready for install , it is backing plate to backing plate . E-mail me if you need more info . It has been refurbished . BOB
Bob Kelso is offline
Old April 21st, 2011, 07:46 AM
Olds Dreamer
alek72us's Avatar
If u get a type O they are hard to find in a posi and hard to find parts for. if ur car is a 72 cutlass then u can do a 70-72 chevelle skylark not for sure but i think nova gt lemans. there are probably more. they are all the same width and bolt ins. the 10 bolt 8.5 parts are everywhere and good priced.
alek72us is offline
Old April 21st, 2011, 07:57 AM
alek72us - only the 'A' body rears will fit, Chevelle, Le Mans, and Special.
Athough close in width, gt[?] and Nova have leaf springs, and won't work.
If I were to change the whole housing, I'd go for a 12-bolt, as the xtra $'s would be worth the xtra strength, to me!
Old April 21st, 2011, 08:18 AM
Olds Dreamer
alek72us's Avatar
but the 12 bolt type O is the same as 8.5 inner as the 10 bolt. so its not much better strength if u want the 12 bolt strength u need the 12 bolt chevy rear end. which is the chevelle.
alek72us is offline
Old April 21st, 2011, 08:39 AM
Sorry - to me, a 12 bolt is ONLY a Chevy!
Yes, the Chevelle is the only one to work in a Cutlass 4-link, and the early 64-67 housings are 2 inches narrower - can help tire clearance!
The type 'O' or 'P' are usually refered to as a 10 bolt 12 bolt, ie: 10 bolt gears in a 12 bolt housing!
Old April 21st, 2011, 08:45 AM
Olds Dreamer
alek72us's Avatar
u r ok we just need to clearify better for the ones asking the ? so we don't confuse then more then they need to be.
yes if u need x-tra strenth the 12 bolt chevy would be best. the type O i would get if i was doing a stock/stock build. but the 10 bolt 8.5 is cheap/available/u can also make the strong.
alek72us is offline
Old April 22nd, 2011, 05:32 AM
The 12-bolt O-axle does have an 8.5" 10-bolt ring gear,but those internals are unique to themselves.You can NOT install the 71-up 8.5" 10-bolt guts into the 12-bolt O-axle housing.
Deedsntitles,
I can sell you a completely rebuilt 71-72 8.5" 10-bolt posi rear,any gear ratio,for $975.00 plus the freight.Everything inside is new.This is the same style rear that came in the 71-72 Cutlass/442,and the 71-72 Skylark/GS.These are good rears,and will handle plenty of power.
Old May 8th, 2011, 08:38 PM
317Cutty's Avatar
Rick,
507olds aka Trick is very knowledgeable about the Cutlass game and expecially those rear ends. We have dealt with him before and I can say he is a standup guy....
317Cutty is offline
nj_cutlass72
November 20th, 2019 09:11 PM
350TurBRO
September 12th, 2014 11:52 AM
69OldsCutlassS
September 9th, 2009 01:05 PM
troy1
Ninety-Eight
February 12th, 2008 01:49 PM
johnnybondo
February 11th, 2008 12:04 PM
Quick Reply: Posi rear end
