307 to olds 350 swap
Old May 13th, 2011, 05:22 PM
deltaroads's Avatar
I have an 86 cutlass with the 307 in it and I'm planning on putting a 350 out of a 73 delta 88 in it. Plan on doing a few small things to the motor, like a small cam and maybe bore it a little, but mainly want a good street car. What all will swap over from my electrical stuff to that motor?
deltaroads is offline
Old May 13th, 2011, 06:56 PM
Don't do a cam unless you are going to rebuild the entire motor. Usually the bearing go not too long after a cam swap.
Anything on the Cutlass will swap over to the 350
Old May 13th, 2011, 08:32 PM
Dragonist's Avatar
its all straight forward..swap all the stuff over to my 350, but my olds came with out the ccc
Dragonist is offline
Old May 14th, 2011, 08:21 AM
The 307 and 350 are externally identical. EVERYTHING swaps. If you don't have the CCC system, you're good to go. Be sure to swap the water pump, accessory brackets, and pulleys as a matched set to avoid alignment issues. Also don't forget the PS pump bracket spacers.
Old May 14th, 2011, 08:54 AM
84oldsDelta88's Avatar
Super easy swap, almost everything should swap over from the 307, Just finished this swap in a 84 delta 88, you'll love it when its done
84oldsDelta88 is offline
MrLightning
July 19th, 2017 07:48 PM
falconsfan
May 14th, 2015 05:47 AM
HARDLUCK88
April 22nd, 2009 10:39 PM
wdm3000
January 22nd, 2008 12:12 PM
Pinner
March 11th, 2007 07:11 PM
Quick Reply: 307 to olds 350 swap
