Kickdown switch For 67 Cutlass
Old October 3rd, 2011, 05:48 AM
Sid
Sid's Avatar
I need a working Delco kickdown switch for a 67 Cutlass that was for a Jetaway Trans that was mounted up by the Firewall and trans linkage.
SID
Sid is offline
Old October 3rd, 2011, 08:29 AM
http://www.yearone.com/serverfiles/f...down&SM=1&SC=3
Old October 3rd, 2011, 08:48 AM
TripDeuces's Avatar
He's looking for one of these:
TripDeuces is offline
Old October 3rd, 2011, 08:50 AM
Oohhhhhh......they changed them. Gotta love that.
Old October 3rd, 2011, 08:51 AM
TripDeuces's Avatar
Lokar makes a throttle assembly for a Chevelle that fits but doesn't have a kick down switch. If you buy me one you can have my old one
Old October 4th, 2011, 06:03 AM
f-85's Avatar
I have some for th400s. On in a 67 88 i can take pics if needed. Thanks
f-85 is offline
Old October 4th, 2011, 08:10 AM
I know just what you're talking about. TripDeuces is right. It's not a kickdown cable. It's an electric switch that is part of the throttle linkage. I looked all over, and these are not made new by anybody.
I needed one about two weeks ago for my '67 Delta 88. There were two versions of it, a square one made by Littlefuse and a round one made by Delco. Either one will work. Both have the same mounting holes, throttle linkage components, and electrical pin connectors. There were just two different suppliers back in the day.
The same switch was used on ALL '67 Oldsmobiles with automatic transmissions except for the Toronado. Doesn't matter if the car had the 2-speed Jetaway or 3-speed THD. I think this same switch was also used on '66 and '65 Oldsmobiles as well. '68 and later was altogether different.
Here's two photos of it:
The car will not move without this switch, because, as you note, this is an integral part of the throttle linkage.
I bought an NOS piece for $95 from www.nospartsfromthepast.com. The fellow that runs the site was VERY helpful and responded and shipped quickly. Yes, the price was a bit high, but if you need one of these, you need one. And this piece was not taken off another car. It was new in the 1967 box. What you see in the photos is the actual piece I received.
He had TWO of these at the time I contacted him, and I'll bet he still has the other one.
jaunty75 is online now
Old October 5th, 2011, 04:14 PM
66-3X2 442's Avatar
According to the 66-67 Olds parts book,66 & 67 switches are the same. The part # is 1993355 and 355 is the # on my used unit. I have no idea about the one pictured above and that # does not show up in my parts book for any 66 or 67 application. It could be a unit that had a superseded part #,not sure though.
66-3X2 442 is offline
Old October 5th, 2011, 05:44 PM
67 Cutlass Freak's Avatar
I'm pretty sure I have one. I'll do some digging to try and find it tomorow. Let me know if you don't need it any more PLEASE. It might take me a couple hours to find it.
67 Cutlass Freak is offline
Old October 6th, 2011, 07:14 AM
I believe the same part is used for an St300 or 400. The 65 setup was different!
Old October 11th, 2011, 10:18 PM
67442nut's Avatar
If 67Cutlassfreak doesn't have one I do.
67442nut is offline
jstrits
January 4th, 2014 04:05 PM
Flye
July 15th, 2009 09:25 PM
Flye
April 2nd, 2009 05:17 AM
Satellitecentral
March 18th, 2009 05:38 PM
nevadacutlass
October 8th, 2007 07:28 PM
Quick Reply: Kickdown switch For 67 Cutlass
