Firing order
Old October 21st, 2011, 02:23 AM
burnout-dave's Avatar
Firing order
Hi!
Is 1-8-7-3-6-5-4-2 the correct firing order for early Olds engines (303, 324)?
And the cylinder numbers are: Look in front of engine:
right bank: 1 3 5 7 left bank: 2 4 6 8
And distributor turns clockwise.
I hope thats correct.....
burnout-dave is offline
Old October 21st, 2011, 02:57 AM
I have no personal knowledge of this engine, but according to these folks, that firing order's right, but you've got the banks reversed (like newer GM engines, #1 is the front Left). You can double check the distributor direction by turning the crankshaft with a wrench if nobody else can confirm it.
Old October 21st, 2011, 03:23 AM
Thank you, according to the link the cylinder numbers are correct, because
I wrote: Look in front of the engine. (standing in front of the hood).
They wrote (left bank: 1-3-5-7 right bank 2-4-6-8). I think they mean from
driving direction, from inside the car.
That should be OK.
But in what direction turns the crank when its running?
Old October 21st, 2011, 03:33 AM
That should be OK.
Old October 21st, 2011, 03:39 AM
Crank should turn clockwise (when looking at it from the front), but you can confirm by watching the engine turn while you crank the starter.
... And by convention, when people talk about the left and right sides of the engine, they refer to the sides of the engine on the left and right sides of the car (not left and right when looking at the engine with the hood open) - if you do it the opposite way, tremendous confusion will ensue, possibly ripping a hole in the space-time continuum .
Old October 21st, 2011, 05:02 AM
I've seen this happen, and it's not pretty.
Eddiejr
June 25th, 2012 10:55 AM
69sAndrew
October 24th, 2009 10:57 AM
72rocket
December 30th, 2008 08:31 AM
monahans10
March 9th, 2008 07:58 PM
oldcutty
September 14th, 2006 09:20 PM
Quick Reply: Firing order
