12 bolt OLDS 'O' Type posi units
Old January 27th, 2012, 06:18 AM
monzaz's Avatar
I have NEW Eaton type posi unit that fit all 3.08 3.23 and aftermarket 3.42 and 3.90 Richmond gears. The most popular gears wanted.
>>>>>>>>>>> 489.00 NEW <<<<<<<<<<<<
Also will have a few 2 series 2.56 2.78 posi units available soon.
Reconditioned units GM 379.00
Also have 3 series (3.08 3.23) carrier reconditioned units 325.00
======== WINTER RESTORATION FREE SHIPPING SPECIAL!!!! =============
monzaz is offline
Old January 27th, 2012, 04:31 PM
dre
dre's Avatar
Will any of these fit a 8.2 housing?
dre is offline
Old January 27th, 2012, 04:36 PM
not to steel the thread but....dre, i still want to see a video of the engine running. just like to see my old engine brought back to life.
jensenracing77 is offline
Old January 27th, 2012, 04:43 PM
dre
dre's Avatar
Eric, she's not running yet. Decided to do a frame off and have the block sent to a different machine shop. My neighbor had some issues with his block and I wasn't comfortable. It's going to a hi performance shop in about two weeks. Frame is painted, now working on the suspension and getting parts for the rear end together.
dre is offline
Old January 28th, 2012, 08:26 PM
capstoneclub's Avatar
I need a 3:23 rear gear/pinion for my 70-442. Let me know if you can help.
thanks
capstoneclub is offline
Old January 28th, 2012, 08:34 PM
70 Cutlass SX
pcard's Avatar
Jim - Email sent.
pcard is offline
Old January 30th, 2012, 06:28 PM
Olds Nut
m455sx's Avatar
i need a posi for my 323, 23139 zip code what is shipping
m455sx is offline
Old January 30th, 2012, 09:19 PM
monzaz's Avatar
posi shipping
15.00 to all US 50 states
excludes PR VI etc.
monzaz is offline
Old January 30th, 2012, 09:25 PM
monzaz's Avatar
10 bolt 8.2
10 bolt 8.2 posi units are as follows
NEW Eaton unit (3.36 3.55 3.73 3.90 4.33) 429.00
NEW Auburn unit (3.36 3.55 3.73 3.90 4.33) 409.00
NEW Auburn unit (2.93 3.08 3.23) 409.00
Reconditioned factory GM unit (2.93 3.08 3.23) 299.00
Factory gears 2.93 - 110.00
Factory gears 3.08 - 130.00
Factory gears 3.55 - 150.00
Aftermarket 3.55 - 279.00
aftermarket 3.90 - 249.00
aftermarket 3.73 - 259.00
JD
monzaz is offline
Old January 30th, 2012, 09:51 PM
Do you include the 'whale oil' posi additive if someone buys a R+P and Posi unit as a package??
Old January 30th, 2012, 10:09 PM
Jim you rascal! Should have waited to buy mine! Naw, You gave me a great price; I got no worries. Sounds like some more of us are going to end up with sweet posi rides soon
EDIT: Hocus Pick! I just went back and looked at the thread title. These are for O 12bolts. Mine was corporate 10 bolt. I feel silly now...
Old January 31st, 2012, 05:37 AM
These are nice units guys.His machinist can get things done a lot quicker than mine.
Old January 31st, 2012, 05:42 AM
Tony72Cutlass'S''s Avatar
Allan tells me that you do great work!
What's the difference between Factory and Aftermarket? Sometime in the sort-of future i'd be looking for a Posi to replace my 2.73 peg-leg in the rear.
Any suggestions? Not sure if I'd like to keep the gear ratio the same. I'm still in the debating stage..
JD
Tony72Cutlass'S' is offline
Old February 1st, 2012, 06:05 AM
monzaz's Avatar
posi units
Factory - units are always cone type and normally made to do regular driving as this was factory equipment and always had a compromise between performance and longevity in the wear department.
Aftermarket - usually finds the weak spots and improves in that area and gives you more preload and grip Plus the material is better design parts better for better strength to handle the torque and horsepower to the ground.
NEW unit also come with manufactures 1 year warranty from defects.
IF you are 12 bolt olds and you are keeping the stock 2.78 (2.73) we do make units for it. There is sometimes a wait time for the building of them. I have 3 being made right now and with the out look of gas being 5.00 a gallon I am looking to make more. They are selling well.
If you have a 2.78(2.73) Pontiac Buick Oldsmobile 8.2 2series are not available aftermarket - we will need to find a 2 series factory unit.... we have done one BUT again it will take more money as there was alot of machining to the unit we needed to use to make it work.
Most of the time if your willing to pay the large chunk of money... I can usually figure iout a unit to work....BUT you the customer have to weigh that out how badly to really need to have it. lol.
MY JOB IS TO TRY TO FIGURE OUT A REASONABLE WAY TO GET POSI IN TO YOUR RIDE...WITH OUT PAYING A ARM AND LEG.
IF you think your muscle car posi unit are expensive you really need to check out the imports they pay 1500-3000 for posi unit....!!!! CRAZY!!!
i did a 370 Z (or something like that) and the total cost for 4.09 gears posi and bearing (parts alone ) were $2750.00 bearing kit was 550.00 woof! Everything came from nippon Japan.... so there was shipping on top of that. GOD!
Any way always ask brian or I will do our best to always help you out with any questions.
JD
monzaz is offline
Old February 1st, 2012, 02:55 PM
oldsmobiledave's Avatar
attention
Please check your PMs so we can finish off our business on a reconditioned 3.08 / 3.23 Type O posi unit & installation kits etc.
thanks
dave
oldsmobiledave is offline
Old February 29th, 2012, 04:23 PM
Good Seller
Posi carrier & parts arrived in Calgary today for the Type O rear end in my gold 1969 442.
Parts were fairly priced, well packaged & shipped at cost. Seller is reliable & communicative. I recommend Jim Mitschke to other board members.
The parts will be installed in April. I will post a burnout pic soon after.
Old February 29th, 2012, 05:39 PM
70 Cutlass SX
pcard's Avatar
I second that opinion of Jim's work. He has reconditioned an original 2 series posi for me and I also bought one of his new Eaton 3 series. Both were delivered on time and on budget.
pcard is offline
Old February 29th, 2012, 07:41 PM
What can I say? X3! Jim is a pleasure to work with. I also found his pricing and shipping costs to be excellent. My posi it a series 2 reconditioned 10 bolt though
Old May 10th, 2013, 08:41 PM
monzaz's Avatar
Thank yous
Just wanted to thank you for the referrals / complements. Helps keep me going when things get overly busy and hectic. Thank You I appreciate it. Jim Mitschke
monzaz is offline
Old May 11th, 2013, 08:27 AM
davebw31's Avatar
Jim I have a few questions:
1) What manufacturer for the clutch pack and "S" spring? USA made?
2) What lb. rating for "S" spring?
3) Are any of the parts, pinion/side gears, case, pin, etc. checked for cracks or fractures? Visual or mag. ?
I have three (3) 70' "O" type rears with the 3.23 ratio, but non-posi., (open) that came out of Rally 350 s that I stripped for parts. Before I list them for sale I may want to buy three reconditioned pois. units from you and install them. It may make them more "attractive" to sell and bring more $$$.
thanks for any consideration you may get these questions,
dave b.
davebw31 is offline
Old May 11th, 2013, 08:40 AM
The posi units are modified 8.8 Ford units,just like what SuperCars and other vendors sell,but better price.The clutches are a composite material,and the spring is 300lb.
The other units are Yukon or Eaton,and also started out as an 8.8 unit. These have the 4 springs and plates,and have composite clutch of a different material.Also a good unit.
For a better,more aggressive application,get the original style knurled steel clutches,and tune the unit.
Old May 11th, 2013, 08:56 AM
davebw31's Avatar
Thanks for the info Brian, however I was asking about the reconditioned original used "O" type posi. units, not new !
davebw31 is offline
Old May 11th, 2013, 08:58 AM
His reconditioned units are the Ford units. Not the O-axle 671 units.
Old May 11th, 2013, 09:11 AM
davebw31's Avatar
OK, thanks Brian. Do you know if he mags the cast iron parts, pinion/side gears?
davebw31 is offline
RALLYE KID
December 20th, 2013 11:58 PM
monzaz
September 13th, 2013 10:33 PM
monzaz
May 30th, 2012 04:08 PM
507OLDS
May 21st, 2012 07:29 PM
monzaz
April 24th, 2011 06:12 PM
Quick Reply: 12 bolt OLDS 'O' Type posi units
