Gas tank
Old April 28th, 2012, 03:33 AM
kbdecatur's Avatar
Gas tank
Im tring to drop my gas tank but i want to know if its necessary to take the straps completly off or will the two bolts at the rear near the bumper do the job its a 1972 olds cutlass
kbdecatur is offline
Old April 28th, 2012, 05:13 AM
boese1978's Avatar
probably need to remove the straps so you have room to drop and move the tank towards the front of the car so the fill neck will clear the bumper etc.
boese1978 is offline
Old April 28th, 2012, 06:38 AM
hookem horns's Avatar
I loosened the back bumper bolts and removed the front ones so the tank could slide forward. Hit them with some penetrating oil the day before starting the job.
hookem horns is offline
I agree. There's no way you'll get the tank off without taking the straps completely off. They're not that difficult to remove, anyway, as long as the tank is otherwise supported and not putting weight on them.
Old April 28th, 2012, 09:02 AM
71 cutlass convertible
lshlsh2's Avatar
Drain all the gas you can from the tank. It will make the job easier.
Larry
lshlsh2 is online now
Old April 28th, 2012, 09:20 AM
frankr442's Avatar
Not that difficult to remove - in theory maybe! I thought they had rust in Ohio.
frankr442 is offline
Old April 28th, 2012, 09:51 AM
Nope. No rust here.
Old April 28th, 2012, 10:10 AM
lshlsh2's Avatar
Had rust in Va. where mine was from. Mine had to be cut, It was Grade 8 fun.
Larry
Old April 28th, 2012, 10:43 AM
Yes, just like the others say. If your straps and bolts are rusted it will be a PITA. Just buy new stuff for the reinstall. Makes life easier. You changing the fuel sending unit or is the tank leaking?
When you drop the tank, if it's not a Lansing car you might find a build sheet on top of it.
Please be sure to post pics of the project.
Old April 28th, 2012, 10:59 AM
frankr442's Avatar
I've tried soaking mine with penetrating oil for WEEKS in advance and I still always always end up cutting. I lived without a fuel gage for two years in my 83 Regal . Waited till I had to replace the tank (because of rust) to fix the sender. God bless Rustachusetts.
Old April 28th, 2012, 08:00 PM
1972 98 & 1984 H/O
Danny Boy's Avatar
If you can jack the car's rear axle up about 8 to 10 inches (I rested my rear tires on cinder blocks - front tires on ramps and jacks under the axle)...you can remove the two bolts and drop the tank down and forward under the rear axle on a floor jack without removing the straps completely.
I replaced my sending unit by dropping the tank this way:
https://classicoldsmobile.com/forums...placement.html
Danny Boy is offline
Old April 30th, 2012, 05:26 AM
kbdecatur's Avatar
Gas tank
Thanks everyone for your input all of it was very helpful....
joemo
September 21st, 2022 04:47 AM
bob p
March 18th, 2015 09:51 AM
1carsick
October 17th, 2012 09:10 AM
Texas442
January 30th, 2012 05:36 PM
JoshF85
October 20th, 2005 12:40 PM
Quick Reply: Gas tank
