how much r12????
Old May 20th, 2012, 09:17 PM
cutlassclay's Avatar
how much r12????
im installing a new compresson into my 72 cutlass and i need to know how many oz or lbs of r12 (freeon*) to put into compressor...please help me before the hot weather comes
cutlassclay is offline
Old May 21st, 2012, 03:23 AM
From the '72 CSM:
MDchanic is online now
Old May 21st, 2012, 04:17 AM
FAZ442's Avatar
I think you need to take it to someone licensed to get r12. Not sure about your state but here in TX you cant put r12 yourself.
FAZ442 is offline
Old May 21st, 2012, 04:20 AM
Yeah. There's lots of things you "can't" do yourself.
Except you can.
Old May 21st, 2012, 05:21 AM
Except you can.
Couldn't have said it better.
If you have the evacuator, gauges, and knowledge, and the system was functional and holds a healthy vacuum for a while, then go for it. Make sure the little valves in the charging ports are in good shape, and tight before hand (use a tire valve tool to check.)
Old May 21st, 2012, 06:30 AM
Yeah, if you keep your eyes open, you can get R12 recovery units really cheap now. I got one for $30.
The garages aren't doing R12 anymore and they just want to get rid of that junk.
If you need to buy R12 legally, you can take this test from the EPA: www.epatest.com/609/ (I'll make a fancy link when I'm not on my phone), through Mainstream Engineering, which is certified by the EPA to certify technicians.
Old May 22nd, 2012, 05:25 PM
I got some r12 and put it in but ac still isn't working...the lines are frosty...do you guys know what's wrong?
Old May 22nd, 2012, 07:22 PM
There are a raft of possibilities.
Do you have a gauge set? What are the pressures?
What's going on in the sight glass?
Old May 23rd, 2012, 02:06 AM
how much did you pay for your R12? that stuff is high enough now that you want to be very sure your system is good before adding the R12. last i knew it was around $100 per lb. i see little cans at flee markets now and then for $20 each.
jensenracing77 is offline
Old May 23rd, 2012, 05:21 AM
Yes, we must know the high and low side pressures, the fan speed you were using, and ambient (outside) temperature. How much did you put in? Stock A/C system?
Old May 23rd, 2012, 05:25 AM
I think the system holds about 4-5 cans or lbs of R12. As said you can charge till sight glass is clear on receiver drier. If still not working you need gauges to check pressures.
Oldsmaniac is offline
Old May 23rd, 2012, 06:32 AM
i used gauges and the pressures are fine...i dont have a sight glass haha so i guess its a gut feeling....i got the r12 from my uncle, he bought lots of it years ago before it went out...and we put in 4 cans......NEW update i opened up the dash and looked at the doors and flaps and they are working fine but that coil radiator looking thing isnt cold at all when i turn on the AC, so is it possible that there is a blockage and its not allowing the coil to get cool?
Old May 23rd, 2012, 08:19 AM
If there was a blockage, then pressure on the high side would be too high. Belt could start slipping, too. What actual numbers were you getting? We cannot really help unless we know the specifics - pressures hi & lo, temp, RPM, fan speed.
Did you evacuate the system with a vacuum pump? If it had air in it, then evac is a must.
With normal pressures, the evap should be somewhat cool.
Old May 23rd, 2012, 08:42 AM
Do you know where to look for the sight glass? What lines were frosty? Are you sure the compressor clutch is engaging? Yes pressure readings seem like a must now.
Old May 23rd, 2012, 09:05 AM
also, is the clutch engaging on the compressor when you turn it on?
Old May 23rd, 2012, 07:27 PM
Why not?
Has the receiver been replaced?
It should be right in the top of the receiver, visible through a hole in the top of the core support, which probably has a rubber plug in it, as in this picture:
And while I'm at it, here are the performance specs for you to compare with:
lsutigers93
May 18th, 2013 08:56 PM
hurstman1972
August 14th, 2012 06:46 AM
jrw63
February 19th, 2012 09:31 AM
oldsF85Fan
May 12th, 2011 08:17 AM
mmurphy77
June 4th, 2010 08:40 PM
Quick Reply: how much r12????
