Hot air choke tubes,and gasket
Old May 27th, 2012, 11:46 PM
XCELERATIONRULES!
Nasty455's Avatar
1976 Olds 350.
I'm wondering what to use for a gasket?
I'm not using the choke,with the stock intake,as I'm converting to Holley with electric choke.
I've painted the manifold and need to seal it.
Thanks.
Nasty455 is offline
Old May 28th, 2012, 05:14 PM
Use a stock type gasket which is a material that will take the intense heat. make yourself a custom blockoff plate and just bolt it on!
Old May 28th, 2012, 07:34 PM
XCELERATIONRULES!
Nasty455's Avatar
Any idea what the gasket is actually called?
Not sure if it's found in the carb,or emissions section.
Some call it a stove gasket,but I've been unable to find it anywhere.
Thanks.
Nasty455 is offline
Old May 28th, 2012, 11:02 PM
70Post's Avatar
Try a FelPro PN 72586...works on a '70-2 car and likely the same on yours.
70Post is offline
Old May 29th, 2012, 01:22 AM
XCELERATIONRULES!
Nasty455's Avatar
Thank you,much appreciated.
Nasty455 is offline
Old May 29th, 2012, 05:05 AM
Choke stove is what it is called, int he fuel/air / carb section.
WTony
December 3rd, 2014 04:16 PM
WTony
September 12th, 2014 06:10 PM
WTony
January 4th, 2014 07:20 AM
WTony
January 1st, 2011 05:32 PM
Gary's 2 442-S
May 3rd, 2010 08:58 AM
Quick Reply: Hot air choke tubes,and gasket
