1979 olds 350
Old June 12th, 2012, 03:36 PM
old school 94's Avatar
1979 olds 350
I recently bought a 1979 350 olds and was wondering how everyone felt about its potential of being a good strong engine. I don't know much about the engine other than its casting number came back as a 1979 350, most of the people mentioned that it had windowed mains. I would like to know if the mains are an issue also.
old school 94 is offline
Old June 12th, 2012, 06:24 PM
DeltaPace77's Avatar
If your engine does have window mains, depends on what you're doing. I had a window main 403 with cam, intake, headers running pretty strong, and never had any problems. Recall driving a stock 80' 350 Delta 88 with really tall axle gearing, and thing was a real dog. Think you've got your work cut out for you, getting that thing to breath a little better.
DeltaPace77 is offline
Old June 14th, 2012, 07:18 AM
1979
what cooling issues, do i need to get a big radiator or what? Is it an issue that the specific motor has problems with? i am not really going to make it super fast or nothing I just want to put it back together, right. Is there any suggestions for me to do.
Old June 14th, 2012, 01:37 PM
Don't recall mentioning anything about cooling system problems, as should be fine there. I mentioned engine breathing, meaning getting more power from an emissions controlled choked down engine. For the original question, the windowed mains will be fine, unless really going for lots of power and rpm. Only reason they're there, is to trim a few lbs of weight from the block.
Old June 14th, 2012, 03:01 PM
1979 350
Oh ok, I misunderstood you, I might be going with a different setup other than the original setup. So i may need more advice later, but thanks for the help thus far.
halfmoontrail
November 20th, 2015 08:11 AM
July 26th, 2015 03:02 PM
Dead Reckon
March 29th, 2015 06:40 AM
vistacruiser1971
November 28th, 2011 08:00 AM
DeadBang1968
November 24th, 2010 09:18 AM
Quick Reply: 1979 olds 350
