Stuck power seat
Old June 15th, 2012, 02:05 PM
kbdecatur's Avatar
Stuck power seat
I have a 72 olds cutlass and it has a power bench seat that doesnt work is there any way i can make it move manually im not ready to change it out just yet just wanna move it back. Yes its all the way up i purchased from a pretty short guy
kbdecatur is offline
Old June 15th, 2012, 02:14 PM
You could unclip the drive cables and roll it manually, probably.
But why not fix what's wrong?
Does it do anything? Move in any direction, make any noise?
If not, then check fuses, check wire connections, and finally, check the relay under the seat. If it's burned or stuck, it can usually be opened and cleaned up, to get at least a few more miles out of it.
Old June 15th, 2012, 02:20 PM
kbdecatur's Avatar
Im actually converting it to buckets but not right now. Where would the drive cables be? It doesnt make any noise or go in any direction im not interested in fixing it just moving it back b/c its killing my knees...lol...
Old June 15th, 2012, 04:19 PM
The drive cables, and the entire mechanism, are underneath.
You have to remove the seat to get to them.
Eight bolts into the floor, but you need to move the seat forward, then back, to get to them .
Since you need to take it off one day anyway, and since you need to move it in order to take it off (unless you're very patient and have very small fingers), you might as well check the fuses and connections.
If worse comes to worst, you can jumper the motor and the clutch pack and probably get it to move. The wiring and cable diagrams are in the Fisher Body Manual.
plonka
February 10th, 2014 08:15 AM
Bitburger
February 8th, 2013 08:24 AM
70worm
November 1st, 2012 09:22 AM
epinkston
June 11th, 2012 10:51 PM
KZ442
April 10th, 2009 03:16 AM
Quick Reply: Stuck power seat
