Looking for Window Channels
Old July 7th, 2012, 06:18 PM
RandyS's Avatar
I am looking for the channels that hold both the Drivers & Passenger door windows. I am not sure what this part is called, (possibly 'Window Track') but it is a metal channel that the glass fits in to (at the bottom of the glass itself) and rides up and down in. It uses some sort of a seal, or sealer, to hold the glass in place.
Thanks,
Randy
RandyS is offline
Old July 7th, 2012, 07:19 PM
what year and model? the one in the avatar?
jensenracing77 is offline
Old July 7th, 2012, 08:13 PM
Thanks,
Randy
I think you're describing the quarter window chrome sash channel. If you're looking for OEM? Stick with Eric - he has some of the best parts supply of anyone in America as far as I'm concerned.
If you're looking for repop - they make them. Fusick sells them 45.00 per side. While you're replacing these you might as well get some new rubber inserts to go with them. When you're installing the finished product you use a very thin cloth tape between the sash channel and glass for a snug fit, then trim any excess. Do NOT 2 sided tape or glue.
Old July 7th, 2012, 09:40 PM
RandyS's Avatar
Yes, for my 66 442. The pieces I need are for the drivers door and passenger door windows. It is sort of a 'U' shaped channel that the glass fits down in to. There is a piece of what looks like white teflon or plastic at the front of the piece that acts as a guide in the vertical channel. The upper regulator rollers fit in a slot along the length of this piece.
RandyS is offline
Old July 8th, 2012, 05:07 AM
i don't have any 66 parts but you may try 2blu442 or oldspackrat. i think oldspackrat was parting out a 66 or 67, i am not sure if he has any of it left or not.
Old July 8th, 2012, 08:15 AM
oldspackrat's Avatar
I do have a '67 442 shell I'm cutting out. Give me a call?
Thanks.
Scott
c. 317-727-7041
oldspackrat is offline
Old July 12th, 2012, 09:48 AM
RandyS's Avatar
Thanks.
Scott
c. 317-727-7041
Unfortunately Scott did not have the part in usable condition. Anybody else that may have these?
Thanks,
Randy
RandyS is offline
Old July 12th, 2012, 02:08 PM
I'm not sure if I was thinking of the same thing you were. Have a look at page 123 (top middle) of this link. Is this what you're looking for or is it something different? (this link is just to show the picture)
http://www.inlinetube.com/PDF%20cata...dsmobile07.pdf The link shows only 68-72, but Fusick has them for 64-72 if it's what you're looking for.
SC667L 1966-67 Left Sash Channel 42.00
SC667R 1966-67 Right Sash Channel 42.00
Old July 12th, 2012, 02:55 PM
RandyS's Avatar
Unfortunately no, those are not the parts I am in need of, but I really do appreciate you trying to help me out! I was referred to a member named 'archeryshooter' and I believe he has the parts I am looking for!
Thanks,
Randy
RandyS is offline
bluecutlassconv
June 7th, 2012 05:55 AM
dennisspeaks
October 3rd, 2011 09:23 PM
eodette
November 17th, 2010 06:53 AM
1964F85
April 7th, 2010 07:46 AM
mike14_07
Body work
July 14th, 2009 12:55 PM
Quick Reply: Looking for Window Channels
