grease fittings
Old August 27th, 2012, 11:02 PM
Billy
bigrig12's Avatar
Location: St. Albert, Alberta...just outside of Edmonton
grease fittings
hi, I have to replace 3 or 4 fittings that wont take grease on the front end of my 71 Cutlass. What size are used on these cars? I've seen many different sizes before at the parts stores and I dont always trust inexperienced staff. I also dont want to miss checking any either...how many are there in total? I remember my dad showing me how to grease his 71 Cutlass when I was a kid, but that was 25 years ago! thanks, Bil
bigrig12 is offline
Old August 28th, 2012, 03:15 AM
Yellowstatue's Avatar
Each ball joint- four; each tie rod end - four; idler arm usually one; pitman arm usually one...check the drive shaft both ends for two; sometimes the clutch cross shaft has one; take one out and go to the store with it...the drive shaft should be one size smaller...
Yellowstatue is offline
Old August 28th, 2012, 06:33 AM
You can buy an assortment of zirc fittings, then all you have to do is match them up. Sometimes there is caca that builds up in there. You may be able to unscrew the offending ones and clean them out by soaking in solvent.
kstern58
December 28th, 2014 10:57 AM
sweet70oldz
July 1st, 2013 03:22 AM
devmar07
May 14th, 2010 09:23 AM
alsmith
March 9th, 2010 09:30 PM
cornwallis
September 21st, 2009 08:44 AM
Quick Reply: grease fittings
