1968 1969 1970 3.55 posi Olds 88 98 12 bolt rear 10 bolt cover
Old September 11th, 2012, 08:27 PM
monzaz's Avatar
Rebuilt Posi 3.55 Oldsmobile FULL SIZE CAR 1968 1969 1970
New 3.55 After MArket Richmond / Fabcraft Metal works Performance gears
Original Reconditioned 12 bolt Posi unit
31 spline axles
Axle and bearing seal kit installed
Optional LArge 12 inch brake backing place too.
This rear May also fit Pontiac and Buick Full size cars from the same era.
This is the ONLY GEAR ratio in the aftermarket available for this rear differential.
This rear will handle quite a bit of power for your Big Block Full size Olds Pontiac Or Buick car.
1299.00
Yes i can ship...just need the zip code for a quote.
J D
330 990 8155
monzaz is offline
nj_cutlass72
November 20th, 2019 09:11 PM
monzaz
December 17th, 2016 07:37 AM
monzaz
January 13th, 2013 05:33 PM
monzaz
November 12th, 2012 06:32 PM
monzaz
October 2nd, 2012 04:49 AM
Quick Reply: 1968 1969 1970 3.55 posi Olds 88 98 12 bolt rear 10 bolt cover
