Super T-10 trans, flywheel, cluth, shifter
Old May 19th, 2013, 03:03 AM
Vader's Avatar
Super T-10 with clutch, flywheel, shifter, rods, and drive shaft/yoke for use with 442. Trans spins freely and is in good condition.
$950 obo parts in NJ
Vader is offline
Old May 20th, 2013, 10:20 AM
davebw31's Avatar
1) what is the first gear ratio of the Super T-10
2) what is the part # on the side of the main case
3) is this a close or wide ratio trans.
thanks,
davebw31 is offline
Old June 22nd, 2013, 03:14 AM
Vader's Avatar
pics
I have several driveshafts for 70-72 442. also have several shifters. offers considered, pickup preferred. NJ
Vader is offline
Old June 22nd, 2013, 07:00 AM
The Lakewood housing looks like Chevy, as does the flywheel. I didn't check but I believe there are sites which decode the numbers on the transmission.
Old June 22nd, 2013, 08:00 AM
Vader's Avatar
T-10
I don't know anything about these, but I believe it decodes to a 1976 Corvette. The S in the stamp was St louis, where vettes were made.
Feel free to edu me cate me...
Vader is offline
Old June 22nd, 2013, 10:32 AM
MOTORHEAD
11971four4two's Avatar
that is a 1977 VIN
11971four4two is online now
Old June 22nd, 2013, 11:05 AM
davebw31's Avatar
Vader: I am interested in purchasing the trans only. Will you ship?
Also, can not tell in picture, but could you count the number of rings (grooves) radially cut in the splines of the input shaft. This will determine the gear ratio.
thanks,
dave b.
BTW: WL1062 means W-Borg Warner, L10-Dec. 10, Year-76, and 2- 2nd shift
VIN # dictates this was from a 1977 chevy so the trans was built during 1977 production model run.
davebw31 is offline
Old July 3rd, 2013, 01:35 PM
Vader's Avatar
trans
The trans has 3 grooves which I believe is a 2.64 wide ratio.
dave sent you a pm.
Vader is offline
at3regency
July 14th, 2015 04:50 AM
dnmfranco
April 9th, 2014 08:27 AM
August 3rd, 2013 08:10 AM
Vader
August 3rd, 2013 07:50 AM
64Super88
May 15th, 2010 07:24 AM
Quick Reply: Super T-10 trans, flywheel, cluth, shifter
