1970 Cutlass 12-bolt rear end
Old August 11th, 2013, 12:10 AM
HitTheHole's Avatar
I have a 1970 Cutlass Supreme Convertible with a 12-bolt rear end. Was that rear end standard or an upgraded option?
HitTheHole is offline
Old August 11th, 2013, 12:31 AM
It's an O-Axle. 12 bolt cover with a 10 bolt ring and bolt in axles. Standard on all Oldsmobile cars from 67-70 except Canadian built cars.
Old August 11th, 2013, 12:33 AM
HitTheHole's Avatar
Thank you very much for the clarification!
Old August 11th, 2013, 05:27 AM
drop top olds's Avatar
Yes, last year of the O axle. In 1971 went with corporate rear end with bolt in axles (I think).
drop top olds is offline
Old August 11th, 2013, 09:17 AM
And to clarify further, it is not a "12 bolt" axle. The number of bolts refer to the bolts holding the ring gear to the carrier. It is coincidental that on Chevy axles the number of bolts on the rear cover matches the number of bolts on the ring gear. That is not normally the case for most rear axles. The Type O axle uses ten bolts to hold an 8.5" ring gear to the carrier. The Chevy 12 bolt uses 12 bolts to hold an 8.875" ring gear to the carrier. Completely different axles. Nothing interchanges.
monzaz
October 26th, 2020 07:05 PM
rcdynamic88
April 7th, 2015 11:21 AM
350TurBRO
September 12th, 2014 11:52 AM
monzaz
September 11th, 2012 08:27 PM
Aceshigh
June 10th, 2010 08:16 PM
Quick Reply: 1970 Cutlass 12-bolt rear end
