Spark plug gap
Old May 25th, 2008, 10:48 AM
Chumley's Avatar
Spark plug gap
I have a '73 350 with HEI. What do you guys gap your plugs at with this motor?
Chumley
Chumley is offline
Old May 26th, 2008, 03:56 AM
Jim's rare 80
Jim's rare 80's Avatar
73's didn't have HEI. The closest is a 75 for HEI. According to my book, It's R-46SX plugs gapped to .080, and timing at 20B.
Hope this helps.
Jim.
Jim's rare 80 is offline
Old May 26th, 2008, 05:41 AM
Agreed. Gap on an HEI should be 0.060" - 0.080"
Old May 26th, 2008, 06:20 AM
Pghstarsky's Avatar
Damn...that's a big gap. Would that be the same for a 72 350 with HEI upgrade?
Pghstarsky is offline
Old May 26th, 2008, 10:03 PM
Junior Member
88 coupe's Avatar
My book says .040 for all '72 Olds.
No reason to use more, unless cylinder pressures and/or fuel mixtures have been changed.
Norm
88 coupe is offline
Old May 27th, 2008, 01:03 PM
Chumley's Avatar
The motor is a '73, and had HEI added at some point. I'm assuming it's very low compression and small valves. The old plugs were all at .035, but I'm going to go .040 with the new plugs. I run my big block Chevy at .060, and have not had any problems, but I know you can't compare apples to oranges.
Chumley is offline
Old May 27th, 2008, 05:16 PM
Warhead's Avatar
Gap your HEI plugs no more than .060".
I usually go .045-.050".
The "book" says .080 for 76-77 HEI's, it creates more problems than it solves. JMO
Warhead is offline
Old May 27th, 2008, 05:20 PM
I agree.
I also believe that Olds sent out a recall/correction page about the .080 gap issue. Changing it to .060.
I remember writing it on my fan shroud years ago.
Old May 27th, 2008, 06:00 PM
GM Enthusiast
OLD SKL 69's Avatar
I have a 69 350 and took out the points distributor and changed over to an HEI. I gap my plugs at 040 and it runs great. Hope that helps.
OLD SKL 69 is offline
Old May 27th, 2008, 08:25 PM
Chumley's Avatar
Thanks for all the input guys, I gapped them at .045, now I just have to put the new wires together, install, and see how it goes. I wish I had a '72 or older motor. The car is a '72. In '73 everything changed dramatically performance wise.
Chumley
Chumley is offline
bonesbmx
June 2nd, 2020 02:10 PM
ChrisM
March 7th, 2009 08:07 PM
boese1978
March 16th, 2008 03:50 PM
ChrisM
November 1st, 2007 02:23 PM
66starfire
January 3rd, 2007 10:31 AM
Quick Reply: Spark plug gap
