1966 Cutlass 330 OEM throttle linkage options
Old February 25th, 2014, 06:05 PM
Larrys'66's Avatar
I am looking to find advice on options for linking the 1966 Cutlass 330 throttle linkage with an Edelbrock 750 with a Torker intake and a TH 350 trans. The linkage could be reused and the kickdown switch could just stay in place but it would be good to know what others have done to replace it.
I would appreciate other ideas and pictures if they are available. The motor should be in the car by Sunday if all goes well with the brake line conversion.
Thanks....
Last edited by Larrys'66; February 25th, 2014 at 06:39 PM. Reason: Added detail on carb and trans...
Larrys'66 is offline
Old February 25th, 2014, 09:01 PM
Ben
RAMBOW's Avatar
Buy a lokar replacement pedal & cable system, then it will hook up like every other TH350 setup, and you can actually properly adjust the WOT position.
If you haven't put the engine in yet, its the perfect time to do it while you have easy access to the firewall.
RAMBOW is offline
Old February 26th, 2014, 11:15 AM
Larrys'66's Avatar
Thanks RamboW
I had a look the Lokar stuff at Summit Racing, very nice stuff and pricey.... Nothing specific for an Olds though and I would need to confirm if the linkage mounting location on a Chevelle is the same. I know a guy who has a '67 Chevelle, so at least I have a car to compare to.
Maybe I can fabricate a linkage component to take the place of the kickdown switch but I still need to think about the trans.
Old February 26th, 2014, 12:47 PM
Thanks....
I bought linkage parts from McMaster Carr and fabricated my own when I installed an Ebrock on my 62. See this thread for photos. Scroll down to post #19 in that thread.
Old February 26th, 2014, 01:19 PM
All you need is to adapt the throttle rod to the carb and a detent cable with the mounting bracket for a chevy to adjust the kickdown.
Throttle bushing and grommet:
And something like this:
Old February 26th, 2014, 04:22 PM
jag1886's Avatar
Here is how I did it it on my 65, should be real similar on your 66. I removed the stock arm and made a new one using the stock rear pivot a piece of 1/4" metal rod and a new pivot on the front end, all you need all you need is a 1/4" fine thread die to make this and you can bend or make it any length needed.
jag1886 is offline
Old February 26th, 2014, 04:29 PM
ROBZ442's Avatar
This is what I did on my 66 except instead of a rod end I bent a 90, welded a washer in place, and drilled a hole for a cotter pin. Looks very similar to a stock unit. I like this one much better than mine. As long as you thread the rod far enough you will have plenty of room to adjust the WOT position.
ROBZ442 is offline
Old February 26th, 2014, 04:32 PM
I think his bigger concern was how to hook up the T350.
Old February 26th, 2014, 04:36 PM
ROBZ442's Avatar
Sorry about that, I was speed reading, and my slow reading is bad enough. Your answer was correct and would work just fine.
ROBZ442 is offline
Old April 21st, 2014, 06:48 PM
Larrys'66's Avatar
Now that the car is running and driving, it is clear that the stock throttle linkage doesn't have near enough travel to fully open the carb. I get about 3/4 open before my foot is to the floor.
I will take the advice on this thread and work on altering the linkage to see if I can find my secondaries. It was kind of funny to cruise the highway at a top speed of 50 MPH as the mini vans went whizzing past.
Old April 21st, 2014, 08:48 PM
I reached under the dash and bent my gas pedal arm up a hair at a time until it opened full throttle.
Old April 22nd, 2014, 03:32 PM
jag1886's Avatar
There is two ways I know of, if your car has always been an auto there is an adjustment below the switch pitch switch on the bottom link that you readjust for more travel and if you hook your carb linkage into a lower hole on the carburetor arm you should be able to shorten the linkage which will give you more travel.
I had to do both on my 65 to get full travel.
jag1886 is offline
Old April 23rd, 2014, 04:23 AM
Larrys'66's Avatar
Thanks Jag1886, I will look more closely. I bead blasted and painted the switch pitch linkage while out of the car and totally missed the adjustment. I did remove the stopper on the linkage to get a little more travel.
L69
September 24th, 2014 03:33 AM
clubw29
December 28th, 2013 06:49 PM
July 5th, 2012 09:34 AM
1k442
February 2nd, 2012 10:45 AM
therobski
April 2nd, 2010 07:33 AM
Quick Reply: 1966 Cutlass 330 OEM throttle linkage options
