1968 TO code posi rear end
Old March 14th, 2014, 01:53 PM
Bob Kelso's Avatar
I am assembling a 3:91 posi rear end , it is the 1968 31 spline TO code set up . It has been sandblasted - primed - painted . new axle bearings - seals , new pinion bearings - new carrier bearings - new crush sleeve and pinion seal . The posi has been rebuilt with oem steel clutches , new gear lube and posi additive , new vent tube - new upper control; arm bushings , it will be backing plate to backing plate . It will have the big cone style brake drums . Do not want to ship , pick up at my location in Hebron Illinois zip 60034 .Price is $1400 . Here are some pictures of the housing and axles -posi unit . Housing has no pitting and all parts are in very good condition .
Bob Kelso is offline
Old March 16th, 2014, 09:02 AM
servexcell's Avatar
I have a 68 Cutlass Convertible it does not have posi , I suppose it does not have a posi unit. I am sure it has a twelve bolt do you have a posi unit I can install without replacing the whole rearend
thanks
servexcell is offline
Old March 16th, 2014, 02:28 PM
Bob Kelso's Avatar
You need to know what gear ratio you have to determine what posi unit you need . Some of the Cutlasses had Chevy 12 bolts in them , you need to find out if it is the o-axle or Chevy style . BOB
Old March 21st, 2014, 03:35 PM
Bob Kelso's Avatar
I have added pictures of the rear end . BOB
shamusj
January 14th, 2015 12:34 PM
oldspackrat
October 7th, 2014 05:15 PM
RALLYE KID
December 20th, 2013 11:58 PM
monzaz
October 2nd, 2012 04:49 AM
Quick Reply: 1968 TO code posi rear end
