dropped spindles
Old September 6th, 2008, 01:47 PM
Rangerdog's Avatar
dropped spindles
I am converting front drums to disc on my 67 Cutlass.I plan on using the MGM disc conversion kit.I want the car to have a nice rake look to it so I was considering using a 2 inch dropped spindle.Right now I have 6 inches of clearance between the lowest point to the ground.Will 4 inches be enough clearance?Anyone have suggestions how I can get that stance for my vehicle?
Rangerdog is offline
Old September 6th, 2008, 02:11 PM
Not on my drive way
Jamesbo is offline
Old September 6th, 2008, 02:36 PM
csstrux's Avatar
Dropped spindles would allow you to run stock geometry on the alignment. I have heard of people either cutting a coil out of the spring, or heating them. I haven't done any of these. but would recomend the spindles IMHO. Or you could go with wagon springs in the rear. You would elevate the tail a couple inches and get a tighter ride without sacrificing ground clearance. A talk with the local front end shop couldn't hurt either, they should have the low down on what works, and what will last
csstrux is offline
Old September 6th, 2008, 03:16 PM
Unless somehas come out in the last year to correct it don't use drop spindles. They will throw geometry off and cause bump steer issues. Ultimate way to go is AFX spindle. Poor mans way (what I am doing) will get you with in 90% of the benifits of the AFX. I am using the Tall ball joints from SC&C and Eibach springs. You can skip the springs if you won't want real low.
Old October 4th, 2008, 11:37 AM
mp71conv's Avatar
drop spindles
I used 2in drop spinles on my 71 cutlass conv and it looks good.
I rebuilt the front end at the same time and had it alligned and have no
problems of clearence or driving
mp71conv is offline
Old October 4th, 2008, 05:01 PM
You are confusing the use of B-body spindles with the use of dropped spindles. The B-body spindles have a different steering arm location, hence the bump steer. If the dropped spindles use the original steering arms and is the same height, the suspension geometry will be exactly the same. The only change is that the actual spindle post is relocated higher up on the steering knuckle.
copper128
August 18th, 2015 11:39 AM
copper128
December 5th, 2013 06:59 PM
moberg
Ninety-Eight
22
December 27th, 2009 09:13 AM
Alocatelli
March 12th, 2009 04:43 AM
moberg
March 4th, 2009 12:13 AM
Quick Reply: dropped spindles
