Oil filter housing - must remove exhaust manifold
Old March 2nd, 2024, 02:11 PM
getmygoat's Avatar
Hi all,
Considering swapping in a new oil filter housing gasket (olds 350). Looks tight with the exhaust manifold. Anyone know if I can swap this w/o removing exhaust manifold? Its a 76 cutlass, has cross over pipe and head pipe plumbed to that right side exhaust manifold.
Thanks!
getmygoat is offline
Old March 2nd, 2024, 07:04 PM
You should be able to access the three bolts without removing the manifold. I would start by unscrewing the filter and removing the torque converter dust cover to improve access. That 1976 manifold isn't doing you any favors. You might also consider removing the strut that runs from the frame to the crossmember on that side.
joe_padavano is offline
Old March 4th, 2024, 07:29 PM
getmygoat's Avatar
Thanks for your insights.... Guess I'll just have to dive in and learn as I go.
PaulWinn
January 18th, 2023 06:51 AM
67cutlassguy
June 10th, 2018 06:12 PM
srholt45@gmail.com
September 30th, 2016 05:56 PM
Col Wickham
December 13th, 2009 06:30 PM
67_cutlass_s
September 8th, 2007 02:49 PM
Quick Reply: Oil filter housing - must remove exhaust manifold
