How does one remove headlight bulbs? 66 Toro
Old December 12th, 2023, 03:52 PM
mike 66 toro's Avatar
Question How does one remove headlight bulbs? 66 Toro
I need to change the headlight bulbs. I unscrewed the bezel around them. The bezel is loose, but I can not find a way to remove the bezel to get it out of the way of the bulbs. With the light housing up to the limit seemingly set by a stop screw, the bezel hangs up on the bottom edge. Light down it hangs up on the top edge. Anywhere in middle it seems you can't get it past the bulb. What am I missing? Do I need to disconnect its arm from the lifter actuator? Or run that stop screw in?
Picture just for reference
mike 66 toro is offline
Old December 12th, 2023, 03:58 PM
ourkid2000's Avatar
I had mine out not long ago. I remember it being a bit fiddly but it came out. I think you just have to fiddle around with it until it comes out. I do remember that it was much more difficult to get back in than out.
ourkid2000 is online now
Old December 13th, 2023, 07:39 AM
Indeed. It seems previous owners lowered the upper stop point of the doors and raised the aim of the bulbs to compensate. For aerodynamics? Had to raise the stop so the bezels could clear. Still fiddly, but much less impossible.
Old December 14th, 2023, 09:27 AM
torotoyguy's Avatar
While you're working to remove the headlight surround, I might suggest placing some heavy fabric or a wet chamois between the surround and the adjacent body to protect the paint (on both) from damage. It's been a long time since I've done any bulb replacements, but as others have said, it's not easy.
torotoyguy is offline
Jrodz11
May 11th, 2022 11:19 AM
Chicknj
August 21st, 2017 02:41 PM
GEARMAN69
January 12th, 2016 09:17 AM
KINGONEAL
August 17th, 2013 10:36 AM
scooter123
March 19th, 2012 07:42 PM
Quick Reply: How does one remove headlight bulbs? 66 Toro
