1971 442 w30
Old April 21st, 2022, 11:01 AM
Catdaddy1971's Avatar
1971 442 w30
So I got my old High school car out from my folks place as they moved and was going to start the rebuild process on it. Its been sitting for 30+ years, I had the engine torn down and have had it stored partially together, going to bring it back to the shop that machined it and have them put it back together a good reputable race engine shop, the 4 speed is cleaned up waiting for the motor, so I can at least get it running and moving around on its own power. Then start on the body the trunk and quarters are a little rusty. The hood was restored when I took the motor out as the paint was falling off from it so it is just in primer now. I found this sheet in the back seat wish it was in better condition. Hopefully will try and update as progress is gained. I just found this site and thought it would be great for information that I might need or to ask questions.
Catdaddy1971 is offline
Old April 21st, 2022, 11:14 AM
akspeedy's Avatar
you have come to the right place! Nice ride hopefully you post your progression here I would love to follow! What a car to have in high school love it! Looks pretty good for sitting 30+ years and especially if those are Minnesota plates I see, Welcome!
akspeedy is offline
Old April 21st, 2022, 11:23 AM
4+4+2=10's Avatar
That broadcast card you found is pretty significant. Does the body number on the card match your trim tag located on the cowl just behind the driver side hood hinge?
tc
4+4+2=10 is offline
Old April 21st, 2022, 11:44 AM
I am going to check that out tonight.
Old April 21st, 2022, 12:10 PM
Very cool. 👍 Hard to tell. Is that dark green or black? Finding that build card is awesome. Love seeing a true W car that has been sitting. I definitely look forward to seeing your work.
no1oldsfan is offline
Old April 22nd, 2022, 12:04 AM
RocketDevo's Avatar
Nice, looking forward to seeing more.
RocketDevo is offline
Old April 22nd, 2022, 07:19 AM
alain's Avatar
Nice W car should be awesome when done
Alain red W-31
alain is offline
Old April 22nd, 2022, 09:35 AM
Tag
Old April 22nd, 2022, 02:18 PM
Phoenix8990's Avatar
Looks like a great car, even better having been your HS ride!
Steve
Phoenix8990 is offline
Old April 23rd, 2022, 07:34 AM
4+4+2=10's Avatar
Trim tag body number is 399453 broadcast card body number is 301755. Looks like that card is for another car.
4+4+2=10 is offline
Old April 23rd, 2022, 02:12 PM
Your right. That was not mine I went and found mine in with the title it’s pretty bad condition but matching numbers.
Old April 23rd, 2022, 03:51 PM
4+4+2=10's Avatar
Originally Posted by catdaddy1971
your right. That was not mine i went and found mine in with the title it’s pretty bad condition but matching numbers.
bingo !
4+4+2=10 is offline
Old April 29th, 2022, 03:06 PM
Going to bring the carb in to get rebuilt want to make sure this is the right carb
Old April 29th, 2022, 03:22 PM
Mr Shifty Sidney's Avatar
That is the correct carb for your 71 442 4 speed.
Don W
Mr Shifty Sidney is offline
Old April 29th, 2022, 04:39 PM
RocketDevo's Avatar
Shifty Sidney is correct.
Old April 29th, 2022, 05:25 PM
4+4+2=10's Avatar
I do not have a 71 Chassis Service Manual, but my resource identifies a 7041256 as being correct for a Manual trans W-30.
4+4+2=10 is offline
Old April 29th, 2022, 05:45 PM
Perfect then I will bring it in and get it rebuilt .
The manual trans number matches vin also
Old April 30th, 2022, 08:06 AM
RocketDevo's Avatar
The 7041256 Carburetor is a myth. Aftermarket literature assumed the 256 would carry over from 1970.
GM literature, Parts books do not list it.
Old April 30th, 2022, 08:27 AM
There is a difference in a W30 and a 442 carburetor for 1971, also with manual and automatic transmission right.
Old April 30th, 2022, 08:45 AM
No difference between W-30 and and non W-30 carbs in 1971. Automatic and manual transmission carbs are different.
Some of the factory literature for 71 have the incorrect numbers listed. It took a while for me to find out what was correct for my 4 speed. There is not a lot of information out there for the 71s compared to 70s.
Don W
Old April 30th, 2022, 09:30 AM
What was the difference in the 70 w30 and 442 carbs?
Old April 30th, 2022, 03:15 PM
Loaded68W34's Avatar
I believe the 70 W30 carb does not have metering rods while the regular 442 carb does. Someone can correct me if I am wrong.
Loaded68W34 is offline
Old June 27th, 2022, 07:04 AM
Kaline's Avatar
It is very cool that you have this car! Please keep this post updated with progress!
Kaline is offline
Old January 3rd, 2024, 03:23 PM
Getting closer
The motor is almost done had a cracked exhaust manifold so found a good one to replace it. Should be going to the dyno soon. Been a slow process but a good friend has been doing the motor work.
Old January 3rd, 2024, 03:36 PM
Steering wheel?
The steering wheel is really sticky anyway to clean this up or restore it?
Old January 4th, 2024, 12:43 AM
This is another one of those questions where asking 20 people will get you 30 answers. I've always used auto paint pre-cleaner (wax and grease remover). Prep-All is one such brand. Be sure to get the old, solvent-based cleaner, not the new water-based stuff. Just understand that the rubber in the wheel will continue to outgas over its lifetime and you'll have to wipe it down every couple of months or so.
joe_padavano is online now
Old January 4th, 2024, 05:27 AM
dc2x4drvr's Avatar
H heads?
dc2x4drvr is offline
Old January 4th, 2024, 06:13 AM
I believe H heads
Old January 6th, 2024, 01:56 PM
JMJ-RIP's Avatar
I believe H heads
My Tag ST 71 -----LAN367292
It should, my '71 has H heads.
Carb is a 7041253
M22 W/Dual Disc Clutch
lol, yep mine had sat for several years and my wheel too, was oily-sticky.
JMJ-RIP is offline
Old January 7th, 2024, 01:14 AM
herkguy's Avatar
Thumbs up
looking good!
glad you found a usable manifold
herkguy is offline
Old January 7th, 2024, 02:15 PM
  #31
I believe it also has 2 barrel jets in the primaries. Supposedly, the 70 W30 455 manual made very poor vacuum and could not haul those rods up reliably, so they did a workaround, removed the rods, and changed the jets. I do not know what cam changes were made to it to go to 71. It did, like they all did, have less compression in 71. Since the power piston and rod assembly was back in 71, I suppose it made enough vacuum to run it in that config.
Koda is offline
Old January 7th, 2024, 02:45 PM
  #32
OLDSter Ralph's Avatar
1. They didn't use "2 barrel jets"......they used a jet size in the SMT carbs that were the right size for a Quadrajet primary bore.
2. The "vacuum" actually holds the primary metering rods down against the power piston spring pressure. Low vacuum allowed the power piston to lift and the smaller end of the metering rods to enrich the A/F mixture.
3. SMT W-30's didn't need the precise A/F as much as the W-30 Auto transmission equipped cars. The "softer" (different vacuum range) power pistons were available through the Oldsmobile dealer parts counter from Rochester. Cliff Ruggles and a few others market similar springs now.
OLDSter Ralph is offline
Old January 7th, 2024, 04:02 PM
  #33
Andy's Avatar
What an awesome high school car, and you had the fore thought to keep it..Very cool, keep showing the progress..I have a 70, I actually like the nose and grill on the 71 better..Kewl ride my friend
Andy is offline
Old April 12th, 2024, 05:53 PM
  #34
Motor is running!!!!!!!!
Old April 12th, 2024, 06:17 PM
  #35
69CSHC's Avatar
Love it ! Looking forward to hear what she is generating.
How close to stock is the build ?
69CSHC is offline
Old April 12th, 2024, 06:43 PM
  #36
Went with close to a 1970 w30 build pistons and cam.
We got 373 hp out of it.
Old April 12th, 2024, 06:52 PM
  #37
69CSHC's Avatar
Awesome !!
The factory saw 372 @ 4800 RPM, I call that mission accomplished .
https://www.motortrend.com/features/...r-1960s-1970s/
69CSHC is offline
Old April 12th, 2024, 09:16 PM
  #38
herkguy's Avatar
Looking sweet!!
just in time for some spring fun 👍👍
herkguy is offline
Old April 13th, 2024, 12:40 AM
  #39
Wheeler used to build some good engines. What "W-30 cam" are you referring to " ? 285/287 ?
Rams442
May 25th, 2020 06:54 AM
bwayco
August 28th, 2017 11:09 AM
Johnnie5
September 6th, 2016 05:39 PM
70W30Jim
March 1st, 2016 12:37 AM
BritishEngineering
October 29th, 2012 05:36 PM
Quick Reply: 1971 442 w30
