1987 442 rear end
Old August 20th, 2013, 12:56 PM
Fastbrianman's Avatar
1987 442 rear end
I found a wrecked 87 442 in the junk yard today.
Any chance that it is an 8.5 rear end?
Thanks,
Brian
Fastbrianman is offline
Old August 20th, 2013, 01:09 PM
www.gbodyolds.com
88hurstolds's Avatar
Yes, crawl under and look and see if it has square fangs on the bottom.
88hurstolds is offline
Old August 20th, 2013, 02:16 PM
Thanks,
Brian
If it's a real 442 with the original rear, it will be an 8.5" 3.73:1 axle.
joe_padavano is online now
Old August 20th, 2013, 06:54 PM
Thanks, Going back to get it in the morning. It is the real thing but it was trashed. Wrecked up front, engine and trans gone some one destroyed the console and dash pulling the stereo system out of it. The damn yard lifted it with a loader under the roof and busted the glass and warped the quarters and dented the drivers door. The only good stuff left was the door panels the steering box and the rear end.
Thanks,
Brian
Old August 20th, 2013, 06:58 PM
Octania's Avatar
might be a posi too
maybe get the driveshaft if it's ok, to match
special code OD trans? Look for a Z among the ID plate letters
Octania is offline
Old August 20th, 2013, 07:00 PM
66400's Avatar
Grab the speedo cluster.
66400 is offline
Old August 20th, 2013, 07:52 PM
brownbomber77's Avatar
What...about...THE LIGHTNING RODS?!?!?!?!? haha Were they in that model or just the H/O G-bodies?
brownbomber77 is offline
Old August 20th, 2013, 07:55 PM
oldsmobiledave's Avatar
Fyi
Also grab the dash inserts & matching pieces from the console. This is the only year that they are not crappy looking wood & fit all the 81-88 models. I have resold complete sets for over $200 .
If the trunk lid is still on the car the sticker on the underside will include the option codes for the 8.5" ring gear (G87), the 3.73 gears (GT4) & posi if applicable (G80).This will verify that the car is in fact a 442 since no other Olds A body got the 8.5" rear end that year.
oldsmobiledave is offline
Fail!
FAIL!
Only in the 83-84 HO from the factory.
Old August 20th, 2013, 07:56 PM
Big Daddy No Bucks
ThePackRat's Avatar
Most definitely if it's still there ...
1 year only 120 speedo.
Nope ... 83/4 Hurst only.
ThePackRat is offline
Old August 21st, 2013, 03:24 PM
BlackGold's Avatar
Are you serious?! I cna't stand the crappy black plastic inserts in my '87 442 compared to the nice burlwood ones that were in my '85 442. They may not have been real wood, but they looked a hell of a lot better. To each his own, I guess.
Everything about the '87 is cheap compared to the '85. The only good thing better in the '87 is the 120 mph speedometer.
BlackGold is offline
oldspackrat
January 20th, 2015 09:16 AM
350TurBRO
September 12th, 2014 11:52 AM
monzaz
March 20th, 2009 02:28 PM
monzaz
February 15th, 2009 07:33 PM
easytobedead
Drivetrain/Differentials
August 30th, 2008 06:04 PM
Quick Reply: 1987 442 rear end
