68 442
Old February 15th, 2008, 09:45 AM
olds4life's Avatar
68 442
need opinions: bought 68 442 that was a stick. it came with no motor or trans. should i go back with stick (don't know how to drive one) or go with automatic. how would this affect value of car and what motor should i put in it. if i go with stick, who/were can i get one from. thanks
olds4life is offline
Old February 15th, 2008, 10:33 AM
Oldsmaniac's Avatar
It seems these days originality means a lot so I would say it would be worth while to get it back to original. As for learning to drive stick it is not hard and with a musclecar its quite fun....as long as you are not stuck in bumper to bumper traffic for miles. Components to get it bact to original can be found at swap meets, online sites such as this one and of course EBAY!
Oldsmaniac is offline
Old February 15th, 2008, 11:26 AM
olds4life's Avatar
thanks. so should i put a 400 back in the 68 442.
Old February 15th, 2008, 11:42 AM
Oldsmaniac's Avatar
If it were me I would look for a 68 to 69 vintage 400 for it.....the earlier 400's had a different casting letter and different stroke and bore. The 400 was gone in 1970 with only 2 choices for a V-8....the 455 and the small block 350. The trans you need is a muncie coarse spline unit used by Chevy, Buick, Olds, and Pontiac.
Old February 15th, 2008, 12:38 PM
I'll always take a stick over an automatic. As for originality, you don't have the original engine and trans, so it will never be original. Use a 455 and paint it bronze. The G-block 400 is not Oldsmobile's best engine.
joe_padavano is offline
Old February 15th, 2008, 01:09 PM
Jolly Green's Avatar
Keep the stick. As for the engine, whatever you want.
Jolly Green is offline
Old February 15th, 2008, 03:57 PM
I have never driven a stick... well excet for a 1991 Hyundai Excel. You might want to do some reasearch first though. I have heard that the Muncies are quite pricey. I do believe there are other manual transmissions you can get for Olds engines that are just as good if not better than Muncies. I have always been an automatic man myself, but I think it would be fun to drive a muscle car with a stick shift.
Olds64 is offline
Old February 16th, 2008, 04:47 AM
viper771's Avatar
I would say go for stick too. I learned to drive stick here in germany while stationed here. I have a 68 olds 442 also, and mine didn't have the orig engine in it anymore. Its a 455. I have been thinking of either putting an orig 400 back into it or keeping the 455. But after some thought, I think I will keep the 455.. I think from the outside, the 400 and 455 look the same. I wish my 442 was stick though!! If you search around, you may be lucky and find someone selling an engine and tranny setup complete for not too much money. you would be surprised
viper771 is offline
Old February 16th, 2008, 06:24 AM
You are supposed to get better gas mileage if your car has a stick. I wonder if this holds true for muscle cars?
Olds64 is offline
Old February 16th, 2008, 07:54 AM
2blu442's Avatar
4 speed vs Automatic
I agree with the other guys about getting a stick, they're a lot of fun to drive and I'm sure you could get the hang of it. The one negative would be if you commmute through LA or Seattle every day as stop and go traffic does take some the fun out of it. Do you have the pedals and Z bar still in the car? I would watch Craigslist.com for a transmission as sometimes you can find someone just cleaning out their garage and willing to sell one for just an arm, not an arm and a leg! But if you price a rebuilt automatic, and I'm always hesitant to buy used automatics, your not going to spend a lot more money on a 4 speed. Also check ebay, if you find one close by you might have an edge not needing to pay shipping. First choice would be a muncie from the 1960's into 1970's, close ratio preferred but don't discount a wide ratio if the price is right. Second choice would be a Super T-10 but stay away from just a T-10 as I think they may not be strong enough for the torque of an Olds 400 or 455. I have a Super T-10 that came out of a late 1970's camaro, so you can look for them there too. You will need to find a crankshaft that is drilled for a pilot bearing or bushing or have a competent machine shop drill one for you. Keep us posted on what you decide, and how your progress is going! John
2blu442 is online now
Old February 16th, 2008, 08:14 AM
Originally Posted by 2blu442
I agree with the other guys about getting a stick, they're a lot of fun to drive and I'm sure you could get the hang of it. The one negative would be if you commmute through LA or Seattle every day as stop and go traffic does take some the fun out of it...
Yeah, that's an understatement. When I lived in SoCal, I rowed my 70 W-30 up and down Sepulveda between Torrance and El Segundo commuting to work. Of course, I also had a very stiff clutch in it. I seemed to get an unusual wear pattern in the sole of my left shoe...
Old February 16th, 2008, 09:30 AM
olds4life's Avatar
guys, thanks for the advise and input. will keep you updated.
Old February 18th, 2008, 12:53 PM
viper771's Avatar
i think there is a 4 sp muncie on ebay right now. Can give you an idea of what that kind of tranny would go for. keep us updated
viper771 is offline
Old February 18th, 2008, 04:29 PM
68conv455's Avatar
No one asked if the pedals and/or linkage is still in place. If the engine and trans were plucked with out taking the other stuff the re-installation of a manual trans will be much easier. The vise-versa applies if someone ran an auto in the car. My ideal combo would be a 455 with a 4, 5, or 6 speed Manual trans.
68conv455 is offline
Old February 18th, 2008, 08:25 PM
shaks 442 clone's Avatar
wouldn't you pay about the same price to put a 4 speed as you would to put a t-56(6 speed) with the right adapter plate?
shaks 442 clone is offline
Old March 11th, 2008, 11:20 AM
dan1s's Avatar
I would put it back to original. 400 / 4 speed. If you can't find a 400 then put the 455 in it. I have a 68' 442 and I have a 400 and 4speed w/3.91
It's a great combo setup.
dan1s is offline
Old March 17th, 2008, 05:25 PM
Cutlass 442 Guy
Green Hornet's Avatar
Shifting
Go With The 4-speed !!!
If you need some stuff to help with the restoration check out
https://classicoldsmobile.com/forums/parts-sale/5960-selling-off-my-stash-gm-olds-performance-parts.html
I am working on a list of parts still available from my "parts car" like fenders, tail lights etc. Let me know what you need.
Good Luck -
Green Hornet is offline
Old March 17th, 2008, 10:16 PM
Good Luck -
what year parts car?
Old March 18th, 2008, 07:48 AM
Cutlass 442 Guy
My parts car was a 1968 442 convertible.
Old March 23rd, 2008, 07:49 PM
442sunbeam's Avatar
all great just keep in mind 4 speed cars bring higher value but its hard to drink a beer and hold your girl friends leg and shift at the same time.
442sunbeam is offline
Old March 24th, 2008, 08:03 AM
Clearly you haven't mastered the art of steering with you knees...
Let's just say that I was able to row my 70 W-30 4spd up and down PCH (first-neutral-first-neutral-first-SECOND!-neutral...well, you get the idea) while also holding a coffee cup (admittedly, a travel mug).
Old March 24th, 2008, 09:29 AM
Past Administrator
Oldsguy's Avatar
Umm, you could always ask her to hold your beer.
Oldsguy is offline
Old March 24th, 2008, 05:12 PM
Dapapadon's Avatar
What he said!
Dapapadon is offline
Old March 31st, 2008, 05:12 PM
442much's Avatar
I'd go with the stick. Learn to drive one. The car is worth what you are willing to sell it for and the buyer is willing to pay you for it. However, I think a correct 4 speed muscle car will bring more money than an incorrect automatic muscle car. But that's just my $0.02
442much is offline
Old March 31st, 2008, 06:33 PM
Cutlass 442 Guy
I vote stick also. I even have a spare transmission which can be had for a fair price
Old March 31st, 2008, 07:28 PM
Senior Moment Member
z11375ss's Avatar
I found a complete 4 speed for 1200 bucks on e-bay. Pedals, springs, rods, you name it it was there. I had the motor redone with the Edlebrock package and the car should be done in two weeks. I'll keep you guys updated. By the way the car was a stout turbo 350 but just damn boring to drive. So I guess my vote is for the 4speed.
z11375ss is offline
