71 Positive battery cable install
Need Help as I want to replace the + battery cable and I find it very hard to get to the back of the engine block to un-bolt.
Is there an easy way to get at it and please note that my car also has headers…
On my 67 Delta, there's actually room to reach the nut with the starter on the motor, due to the driver side exhaust manifold that runs up and over the steering box. On an A-body, not so much.
That OEM starter must weight ~20lbs. Once you remove the starter you'll hate yourself if you don't have something already in place to hold the starter while you remove the cable. Use a small floor jack, small jack stand, wood or something to rest the starter on while you remove the cable.
The OEM starter FEELS like it weighs about 800 lbs after you've been holding it up with one hand trying to get the bolts started. Whenever I have to drop the starter, I ALWAYS install (or at least check) brushes, starter drive, and solenoid.
