Dustcover?
Old August 23rd, 2010, 02:19 PM
Thomas Simcich's Avatar
Dustcover?
There is a part that looks like it covers the ring gear of the clutch assembly, that is missing from my car. Can anyone help me with the name of this piece and where I might be able to find one? It looks as though you can get access to the clutch but also might be some sort of dustcover. Thanks
Thomas Simcich is offline
Old August 23rd, 2010, 02:31 PM
dc2x4drvr's Avatar
Dust shield..Year One, and several other vendors sell this part..
dc2x4drvr is offline
Old August 23rd, 2010, 02:47 PM
Going through the Year One online catalog and found a torque converter dust shield, but my car is a manual transmission. Is this the part?
Old August 23rd, 2010, 03:05 PM
dc2x4drvr's Avatar
I believe so, but it's plastic, originals were metal, contact Brian Trick if originality is important, he might have one.
Old August 23rd, 2010, 03:11 PM
BlackGold's Avatar
Manuals and automatics used a different cover.
For automatics, it is debatable as to exactly when the switch was made from stamped steel to plastic. I've talked to original owners of 1970 cars, some of whom say they have steel, others plastic.
For manuals, be careful what you buy. I don't know the details, since I don't have a manual trans, but I recall stories about the reproduction cover actually being correct for a different make (maybe Pontiac?) and not fitting an Olds correctly. Hopefully someone else will chime in.
BlackGold is offline
Old August 23rd, 2010, 09:20 PM
stan 65 cutlass's Avatar
opg has the muncie dust cover, i need one also, they are about $200
stan 65 cutlass is offline
Old August 24th, 2010, 02:40 AM
Yellowstatue's Avatar
The factory dust cover for a '68 has a full circle of metal that fits around the starter ...later ones had the top of the circle cut off so you don't have to remove the starter to get the shield off ...
Yellowstatue is offline
Old August 24th, 2010, 07:02 AM
Who or what is opg? My car is a 1966 442 with a manual transmission and missing whatever this piece is.
Old August 24th, 2010, 07:09 AM
442Harv's Avatar
Origanal Parts Group
442Harv is offline
Old August 24th, 2010, 07:13 AM
dc2x4drvr's Avatar
Original Parts Group. The Parts Place lists a Bell Housing Inspection Cover for $39, probably plastic.
Old August 24th, 2010, 07:17 AM
Would the "dustcover" from a Chevelle, GTO, or Gran Sport fit my car?
Old August 24th, 2010, 07:39 AM
dc2x4drvr's Avatar
Fusick has a nice repro steel inspection cover for $39..
Old August 25th, 2010, 02:14 AM
Only Pontiac would fit because the starter is on the drivers side as opposed to those lesser brands...
Charles Ludwick
December 27th, 2011 05:49 PM
Quick Reply: Dustcover?
