gas Cap 70 442
If you have a California car with the closed system, you won't have the vent tube that extends upwards from the passenger side corner of the gas tank. You'll have to crawl under the car to check that. If you have the non vented system, you should have three hoses coming from the back of the gas tank into a vapor separator and a return line from the tank to the charcoal canister on the passenger side under the hood. Maybe this has been removed? Maybe capped off in some way?
Texas442
January 30th, 2012 05:36 PM
