Heater hose routing/look
Old August 26th, 2009, 04:25 PM
4speedBench's Avatar
This should be an easy one. I'm hoping one of you guys w/ a 68 442 has a picture of the routing and clips/if any of the heater hoses. I know one is molded and the other, pretty much a straight shot to water pump. I'm replacing the generics that a previous owner had and want to do it correct, clamps and all. I thumbed through my Year One catalog and others but could not find a shot without the air cleaner.
Thanks in advance!
4speedBench is offline
Old August 26th, 2009, 07:35 PM
70Post's Avatar
Factory AC car or not? I assume not.
70Post is offline
Old August 27th, 2009, 08:18 AM
No AC
Old August 27th, 2009, 08:40 AM
Registered
Bluevista's Avatar
Any of these a '68? Cool pics in any case.
http://www.texas442.com/01engines/
Bluevista is offline
Old August 27th, 2009, 07:37 PM
70Post's Avatar
The 3rd and 6th pic in the pics Bluevista linked to should work for you. NOTE the placement of the long heater hose and where it rests on the Non-AC passenger side alternator bracket. That's also where the short black foam insulating sleeve is placed.
70Post is offline
Old August 29th, 2009, 06:12 PM
Thanks guys, helpful.
I noticed there seems to be a mix between whether "hightower" clamps are used versuses tension clamps? My take is tension clamps were used on the heater hoses from firewall, but hightower used on the bypass tube.
Old August 29th, 2009, 06:39 PM
Nilsson's Avatar
Correct on the tension clamps for the heater hoses. The bypass and radiator hoses on a 68 use the double wire clamps not the post type aka hightower clamps
Nilsson is offline
Old September 29th, 2009, 07:39 AM
dan1s's Avatar
Here's a couple for you. Mine is a Sports coupe with no AC.
I don't have any clips. And those are the original hose's
dan1s is offline
Old September 29th, 2009, 10:19 AM
Thanks for the pixs. I plan to tackle this weekend, have been waiting on the back ordered "molded" hose but it arrived today. I'll post the completed set up to finish out the thread for future use.
Old October 2nd, 2009, 06:07 PM
Well here it is completed. Used the YearOne clamp set and also the insulator sleeve over the Alt bracket. Hopefully, it's useful to others down the road. Thanks for comments on this thread.
Old October 2nd, 2009, 07:01 PM
Nilsson's Avatar
Looks good, just one tip once the engine goes through a couple heat cycles go back and re-tighten the wire clamps.
Nilsson is offline
Old October 3rd, 2009, 03:13 AM
Yellowstatue's Avatar
Wink Tight squeeze
The heater hose blew off my wife's car when I used one new wire tension clamp so I put two on tight together and Jane's your aunt
Yellowstatue is offline
Old October 4th, 2009, 05:59 PM
Nillson, Yellowstatue,
Agree. I have re-filled with water for test run, but weather has not been cooperating so I have not had a chance to check for leaks. Got to admit, the tension clamps on the heater hoses have me worried. YearOne sends the same size clamp for both the 5/8's and 3/4 size hoses??? I'm not too confident that I won't have to improvise....
Old October 4th, 2009, 07:41 PM
dan1s's Avatar
Does anyone make this style clamp? This is what I have on mine and should be the original type.
dan1s is offline
Old October 7th, 2009, 01:31 PM
68Tom's Avatar
Dan, I think Fusick has them. Pretty sure that's where I got mine.
68Tom is offline
Old October 7th, 2009, 02:09 PM
dan1s's Avatar
Tom,
I looked in there catalog and didn't see it. I don't need them right now but would like to get them before you can't find them any more.
dan1s is offline
Old October 7th, 2009, 03:16 PM
Nilsson's Avatar
Originally Posted by dan1s
Tom,
That type clamp is readily available. It is found extensively on modern cars and motorcycles. It is used in tight places where a tool such as a screwdriver cannot be used to tighten the traditional type clamp.
No chance of these becoming extinct.
Nilsson is offline
am99888
January 29th, 2021 11:39 AM
Erinyes
July 11th, 2011 08:43 AM
Bushbunny62
September 20th, 2010 07:05 PM
cutlasssupreme71
January 24th, 2010 12:07 PM
Colorado Olds
March 2nd, 2008 01:57 PM
Quick Reply: Heater hose routing/look
